peterc10 Frequent Visitor
Posted: Tue Dec 22, 2009 1:58 pm Post subject: Advanced Planning in Sygic |
Having changed over to Mobile Maps 9 there is one thing that I am missing from my old TTN6 (never thought I would say that). That is the advanced planning option. I found that very useful. I could check distances etc easily (for business mileage records) and if I was flying and hiring a car somewhere I could set it up easily beforehand.
Is there any way to advance plan in Mobile Maps 9 please? I have tried setting an itinerary with just the start and finish point but my present position always gets added as the start point when I go to calculate the route. Any other ideas please? _________________ Peter
HTC Sensation
Copilot for USA
scarymonkey Lifetime Member
Joined: May 09, 2007 Posts: 454 Location: Worcestershire
Posted: Wed Dec 23, 2009 9:56 am Post subject: |
If you set an itinerary with no GPS signal (either turn off the GPS or be in a no signal place) then you will be asked to specify the start point (in the same way you are when you try an set a normal route without signal). So far this is the only way I have found to create an itinerary which doesn't go from your present location. |
Posted: Wed Dec 23, 2009 11:37 am Post subject: |
Scarymonkey
once again thanks for your assistance. It does work but it is much clunkier than TT.
You cannot choose to route from an address or postcode or POI or favourite for example. Instead you can only use your last position, wait for a valid signal or choose a position on the map. A complete pain when you want to know how long it will take to get from one address (airport for example) to another.
You can't use the address of the airport or it being a POI near a city to set your start point. Instead you have to try to find the position of the airport on the map, which starts with a view of the whole of Europe. How do I know where Dusseldorf is on that map and even if I did how would I know where Dusseldorf Airport is in relation to Dusseldorf for example? That is why I need the ******* sat nav in the first place! _________________ Peter
HTC Sensation
Copilot for USA
Posted: Wed Dec 23, 2009 11:57 am Post subject: |
Not sure if you are aware but when you choose the find on map option, click options and then find to give you access to addresses, post codes, POI etc.
I agree it is a little clunky and I did make a suggestion to allow start points to be manually defined easily when McGuider 2009 was first released. Unfortunately nothing much has changed since on this. |
Posted: Wed Dec 23, 2009 12:13 pm Post subject: |
Scarymonkey
that will teach me not to engage mouth before brain!
Thanks for showing how it can be done. Having just checked I can see that it works. So a bit clunkier than TT but still works and does what I want.
It is just a pain having to remember to switch off the GPS before going into the app and then remember to switch it back on again after I have exited. Or is there a way of doing that from within Sygic that I have missed? _________________ Peter
HTC Sensation
Copilot for USA
Posted: Wed Dec 23, 2009 12:31 pm Post subject: |
Are you using WinMo still (mainly because Android doesn't have the option AFAIK)? If so then go to menu/Settings/GPS Hardware and there is an option to turn off the GPS from there. I believe you can also get to this by clicking the signal meter on the front page and then the hardware soft button.
BTW if you have suggestions on improving SMM, Sygic are always happy to receive them on the support@ email address. |
Posted: Wed Dec 23, 2009 8:51 pm Post subject: |
Scarymonkey
I am using Android. And as you rightly say there is no "GPS hardware" option in the settings. And you only get the signal meter when you click on the signal strength meter when you have switched off the GPS, which is useless because all of the info is blank and there is no hardware soft button. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Fri Dec 25, 2009 12:17 am Post subject: |
I should of read your sig as that told me the phone
Android has to be done before launching the app. Much of the blame for this can be placed at Googles door though since they removed the option of standard applications to control location services (turn on/off GPS or cell based locations) with Android 1.5. |
nevinlee Occasional Visitor
Posted: Fri Dec 14, 2012 10:07 am Post subject: |
I am totally agree. You must go for android before launching the application. It will really help you out.
______________________________________
advanced planning and scheduling software |
M8TJT The Other Tired Old Man
Posted: Fri Dec 14, 2012 10:19 am Post subject: |
Did you spot the age of this thread before you posted your blatently advertising addition. |
