drummer Frequent Visitor
Joined: Apr 08, 2004 Posts: 256 Location: Hampton, Middlesex, UK
Posted: Sun Jul 11, 2004 4:55 pm Post subject: |
I am also getting the same error. Has anyone had any success yet? |
Believer Occasional Visitor
Posted: Mon Jul 12, 2004 8:10 am Post subject: |
same here |
simkna Regular Visitor
Joined: 24/01/2003 11:34:45 Posts: 101 Location: United Kingdom
Posted: Mon Jul 12, 2004 8:29 am Post subject: |
Looks like Fortuna have pulled the update from their website until they get it sorted.
Si. |
mpattman Occasional Visitor
Posted: Mon Jul 12, 2004 1:48 pm Post subject: |
I have managed to flash my BT ClipOn, but it would not work through the ClipOnSyncBT application.
After mine failed through the ClipOnSyncBT application, I then edited the "RunExe.bat" file to remove the "-r" from the command line as this was making it fail (as you can see from the "ConsFile") and then re-set up the BT connection and ran the batch file and waited for a couple of minutes (watching the BT activity on the ClipOn) and in the file "RESCOMn" I got a PASS message and in the "ConsFile" had lots of messages about the reflashinging. |
Posted: Mon Jul 12, 2004 1:55 pm Post subject: |
When mine now starts up I get the following:
Code: | $PSRFTXT,Version: 2.4.13.01-XTrac2.0.2-C3EVAL1.0*05
$PSRFTXT,TOW: 0*25
$PSRFTXT,WK: 1265*65
$PSRFTXT,POS: 6378137 0 0*2A
$PSRFTXT,CLK: 96250*25
$PSRFTXT,CHNL: 12*73
$PSRFTXT,Baud rate: 38400 System clock: 24.553MHz*45 |
So it looks like it worked (this was obtained using crux view 1.1.0 and resetting the device and capturing the messages) |
jlw Frequent Visitor
![](http://blodsugare.se/avatar/pocketgpsworld.jpg)
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Mon Jul 12, 2004 4:54 pm Post subject: |
mpattman wrote: | I have managed to flash my BT ClipOn, but it would not work through the ClipOnSyncBT application.
Congrats!!
And how do the xt v2 works? ANy good? ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case |
jalford Occasional Visitor
Posted: Mon Jul 12, 2004 5:27 pm Post subject: |
mpattman wrote: | When mine now starts up I get the following:
Code: | $PSRFTXT,Version: 2.4.13.01-XTrac2.0.2-C3[b]EVAL[/b]1.0*05
$PSRFTXT,TOW: 0*25
I'm a bit concerned that it seems to indicate an Eval version. Is this the same version as everyone else downloaded? |
nightfly85 Occasional Visitor
![](modules/Forums/images/avatars/429fca8c40f03e73acff8.gif)
Joined: Jun 27, 2004 Posts: 17 Location: Riverside, CA USA
Posted: Mon Jul 12, 2004 9:17 pm Post subject: |
When I remove the "-r" from the batch file runexe.bat (which seems to be dynamically created each time you run the bt flash app) I get the following error:
"When programming requested -f and -t should not be specified" so I take these command line parameters out and it executes ok with "target not responding" again. So for me, I am back to square one. |
Posted: Mon Jul 12, 2004 9:20 pm Post subject: |
Ok, I removed the "-sr" from the command line thinking that maybe mpattman mistakenly miswrote the "-r". But I get "target not responding".
mpatman - please post your SiRFflashc1 command line that worked for you in your runexe.bat. Thanks. |
Posted: Mon Jul 12, 2004 9:21 pm Post subject: |
nightfly85 wrote: | Ok, I removed the "-sr" from the command line thinking that maybe mpattman mistakenly miswrote the "-r". But I get "target not responding".
I agree. post it ;) _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Lexar 256 MB
Poporta Alu-Case |
Posted: Tue Jul 13, 2004 9:07 am Post subject: |
This was what I used:
Code: | SirFFlashcl A:\FortunaXTracV202.s -l 4 -b 38400 -c 0 -sr > ConsFile |
My bluetooth port was COM 4 and I set it up first.
I was a little puzzled about the EVAL entry also but it was downloaded from the fortuna site on sunday.
As for perfomance, I could not use XTRAC for tomtom due to the delay but Last night and today I did not notice any significant delay and it worked as well as or better than ST mode for me. |
Posted: Tue Jul 13, 2004 9:50 am Post subject: |
I have just re flashed my device and this is what I did:
1) Extracted the zip file.
2) Copied the file "FortunaXTracV202.s" to the A: drive.
3) Go to the support directory where you unzipped the zip file.
4) Run "ClipOnSyncBT.exe", configure com port and point the application to the flash file on the A drive.
5) Click on the "Com Port Off -> On" button, then the "Link To Fortuna GPS" and then finally the Execute button.
6) This looks like it prepares the device you will notice no activity on the Bluetooth, close the "ClipOnSyncBT.exe" application.
7) Edit the batch file "RunExe.bat" to remove the "-r", mine looks like this:
10) Run the "RunExe.bat" and watch for bluetooth activity.
11) When complete check the "ConsFile" and the "RESCOM4" (number might change depending on your com port.
Here is my "ConsFile" file
Code: | One SST SST39VF800 chip will be programmed
0% transferred, 0% programmed
1% transferred, 0% programmed
1% transferred, 1% programmed
2% transferred, 1% programmed
....... (edited to reduce the size)
98% transferred, 97% programmed
98% transferred, 98% programmed
99% transferred, 98% programmed
99% transferred, 99% programmed
100% transferred, 99% programmed
100% transferred, 100% programmed
Flash successfully programmed in 125.8 sec
Erase time: 3.5 sec, Program time: 28.6 sec |
and my "RESCOM4" file
Ernieken Occasional Visitor
Posted: Tue Jul 13, 2004 10:19 am Post subject: Update succes! |
I've followed the steps as described above without any problems! Same logging as above. Should work for everybody. |
Posted: Tue Jul 13, 2004 10:42 am Post subject: |
I have tried the above instructions to the letter, but I still get the same FAIL and Target not responding errors in the logfiles.
Si. ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Posted: Tue Jul 13, 2004 11:27 am Post subject: |
In step 6:
Whe you pressed 'execute' you can see two windows of the cliponsyncbt application will open: the main window and the window that says it's flashing the unit. I've only closed the main window (so not the 'flashing' window). After that, I executed the command SirFFlashcl A:\FortunaXTracV202.s -l 4 -b 38400 -c 0 -sr > ConsFile from the command prompt.
Good luck!! |
