Pocket GPS World :: View topic - 530 - Sluggish Screen Update.
Blitzer
PostPosted: Tue Dec 15, 2009 11:54 am    Post subject: 530 - Sluggish Screen Update. Reply with quote
Hi all,
I've not been here for a while, mainly because my TT is used occasionally rather than regularly. However, I have recently been used my TT but have noticed that it seems quite sluggish in keeping the map (screen) updated to my position. As a result I've found myself missing my exit on roundabouts several times now and it's becoming frustrating. So really I'm here looking for a plan of action with regards to getting my TT working fluidly again. I'm pretty sure I did notice thing were a little more sluggish the last time I updated the application software to 8.351 and I do have several backups of my TT that I could revert to, but if I do that I'm concerned I may end up with an earlier map version.
I'm currently running...
App 8.351 (9982/090518) OS:315187
GPS V1.20, Boot 5.5120
Map - UK & Rep. Ireland V815.2003
I know my map is a little out of date, but other than that is there a recommended version of the Application software to run if it's not the one I have? I'm not being offered a newer version.
Failing that suggestions for possible solutions would be much appreciated.
Smile
Blitzer
PostPosted: Tue Dec 15, 2009 12:03 pm    Post subject: Reply with quote
Incidentally, I don't have a SD card in my TT - is it something that I should get though, i.e. what are the benefits of doing so?
PostPosted: Tue Dec 15, 2009 12:05 pm    Post subject: Reply with quote
Go to Change Preferences/ Manage POI/ Show POI on map and deselect ALL the POI that are enabled, this should speed up your map refresh rate up by quite a lot - Mike
Blitzer
PostPosted: Tue Dec 15, 2009 12:19 pm    Post subject: Reply with quote
I appreciate the reply Mike, looking now I do have quite a few PGPW POI's ticked, but it seems to kind of defeat the object to having them to a degree. Thing is I don't recall the unit being quite this slow before I updated to app 8.351, but that was quite a while ago and I guess it's possible I've added more POI's since then.
Bearing in mind I have the PGPW camera database installed (the all singing and dancing zoned one) can you recommend rough number of POI's to have enabled to show on the map on top of those? If so any recommendation which ones are best to leave visible?
Thanks very much for your help - much appreciated. Very Happy
PostPosted: Tue Dec 15, 2009 12:45 pm    Post subject: Reply with quote
Use the Change Preferences/ Manage POI/ Warn When Near POI option for each of the cameras and de-select everything in show POI on map, you will still get the warnings as the cameras will show up but this doesn't max out the processor leading to a slow screen, and all the other POI files you have installed can still be used to Navigate to etc - Mike
Blitzer
Hmm, it seems at some point I've accidentally installed more POI's than intended - possibly I have added whole groups rather than specific POI's from PGPW. I have now removed all non-default POI's completely apart from the speed camera database, I'll give this try and see if it has made a difference.
PostPosted: Tue Dec 15, 2009 12:46 pm    Post subject: Reply with quote
Read my previous post as we must have hit enter at the same time, that details what you need to do - Mike
Blitzer
PostPosted: Tue Dec 15, 2009 12:49 pm    Post subject: Reply with quote
Will do Mike, thanks for your help. I'll still test the TT without the POI's being installed at all as this should indicate if they were entirely to blame. A good time for me to completely review what POI I have installed anyway. Will post back with my findings, very much hoping it is exactly as you have said - too many POI's showing on the map.
Actually is it possible or advisable to defrag a TT?
PostPosted: Tue Dec 15, 2009 12:51 pm    Post subject: Reply with quote
No point in doing this as the device uses solid state memory or the SD card which again won't suffer speed issues due to file fragmentation - Mike
GerryC
PostPosted: Tue Dec 15, 2009 1:21 pm    Post subject: Reply with quote
Just to point out that it's nothing you have done to do this. When you upgraded the software, it defaults to making ALL your POIs set to view on the map regardless of the settings before the upgrade.
Remember you can do a test by viewing a route in demo mode. You don't have to go for a drive to see the difference. Smile
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
Blitzer
PostPosted: Tue Dec 15, 2009 1:27 pm    Post subject: Reply with quote
Hi Gerry,
Thanks for the headsup re: the update and making all POI visible on the map. Unfortunately, I will need to test this by driving as my issue was with the map/display not updatingfast enough whilst driving, i.e. the screen was always lagging behind my position to the point where I would think I'd not gone around a roundabout far enough because the TT was an exit behind. Sad
dhn
PostPosted: Tue Dec 15, 2009 1:40 pm    Post subject: Reply with quote
The point is that IF all the pois are set to show, your map WILL be sluggish on rewriting. You don't actually have to make the drive.
Blitzer
PostPosted: Tue Dec 15, 2009 5:53 pm    Post subject: Reply with quote
I appreciate that, but the point is I want to know this is definately the cause of problem for me, it sounds very much like it is, but I'd rather find out before I actually need to use the TT again. Wink
