Pocket GPS World :: View topic - Getting rid or warning screen
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
peterc10
PostPosted: Fri Dec 11, 2009 12:49 am    Post subject: Getting rid or warning screen Reply with quote
I have just started using Sygic Memory Maps. One thing that is irritating is the warning screen that comes up when you first start. I thought I read somewhere on PGPSW that you can edit a file to remove this, but I looked and could not find it again
Anybody know if this can be done please?
Peter
HTC Sensation
Copilot for USA
kartracer
PostPosted: Fri Dec 11, 2009 10:03 am    Post subject: Reply with quote
On my N97 I found that I needed to change the entry:
"showSafetyMsg=true"
to
"showSafetyMsg=false"
within the file:
Mass Memory\Drive\Symbian_Touch\Settings.ini
I presume the exact location of the file will vary depending upon OS and installation location.
Kam
peterc10
PostPosted: Fri Dec 11, 2009 10:31 am    Post subject: Reply with quote
Kartracer
thanks for your help. I should really have said that I have installed this on a an HTC Hero running Android, as i guess that may make a difference!
Using your guidance I found the file "Settings" in Drive/Android, but my file reader (Astro File Manager) is reporting "file type dat no found" and "file type ini not found". So I can't open or edit it. Anybody know of an Android app that will let me do that - it needs to be simple to use otherwise I could end up ruining the thing!
Peter
HTC Sensation
Copilot for USA
kartracer
PostPosted: Fri Dec 11, 2009 12:09 pm    Post subject: Reply with quote
Yes, i see that there is a file in the location you specify which contains the same field. Are you able to sync your phone with, or copy the file to, a desktop computer, edit it on that, and then copy it back? That's how I edited mine.
Kam
peterc10
PostPosted: Fri Dec 11, 2009 1:02 pm    Post subject: Reply with quote
kartracer
thanks - it is easy when you know how isn't it?
That worked with Android as well. The only problem at first was that I did not notice that this entry appears twice, I only changed the 1st one and wondered why it did not work. As always I kept the old file just renamed it (just in case I mucked it up).
Again many thanks. Only goes to show what a great community PGPSW is.
Peter
HTC Sensation
Copilot for USA
norm2002
PostPosted: Sun Dec 20, 2009 2:45 pm    Post subject: Reply with quote
Just tried it on my Windows Mobile HTC HD2. I see there are seperate folders in Drive for Symbian, Android and WM. Changed the entry in settings.ini in the WM folder - only found one entry - and, so far, it seems to be working.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
23.054 (28 May 25)
