keithjeffrey Lifetime Member
Joined: Apr 07, 2006 Posts: 249 Location: Kent , England
Posted: Sun Dec 06, 2009 11:33 pm Post subject: |
keithjeffrey wrote: | Andy_P wrote: | Try it! |
I tried putting the Blue Me version on my 730T.
When I fired it up it started up OK...............Yippee I thought
Then the screen came up with the icons for my vehicle type ( car , van , truck , etc )............... More yippees
This joy was VERY short lived after that.............my 730T locked up and I could do nothing with it.
In the process of reloading my backup , back onto my 730T.
Oh well. |
Also just tried to put 9.022 on my 730T , but that too locked up. _________________ Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419 |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Mon Dec 07, 2009 9:02 pm Post subject: |
Try a hard reset followed by a soft reset and run clearflash a couple of times.
I had similar problems on my XL LIVE but 9.024 is running fine as long as I don't try to use TTS.
I had to do all the resets otherwise all kinds of odd things were happening - remember a lot of settings are stored in the flash memory and it appears that going from Nav8 to Nav9 that is intended for a different device can have all kinds of strange results unless all of the settings and temporary files are cleared. |
Posted: Mon Dec 07, 2009 9:22 pm Post subject: |
AndyVaughan wrote: | Try a hard reset followed by a soft reset and run clearflash a couple of times.
Excuse my ignorance but the only reset I know about is the one on the underside of the unit.
Is that the hard or soft reset ?
How do I do the other type of reset ?
Clearflash - it rings a bell but never done one ( I don't think ) , can you point me in the direction of a description of how to do this .
Thanks in advance for any help given ! _________________ Keith
Posted: Mon Dec 07, 2009 9:36 pm Post subject: |
Hard reset - either a paperclip underneath or hold the power button in until it reboots and you hear the TomTom's depending on model.
Soft reset - from within the software - reset all settings or whatever it is called.
Clearflash - http://www.tomtom.com/6178 |
Posted: Mon Dec 07, 2009 9:55 pm Post subject: |
AndyVaughan wrote: | Hard reset - either a paperclip underneath or hold the power button in until it reboots and you hear the TomTom's depending on model.
Thanks for the link for the Clearflash.
One question though - Reading the TomTom page it says this:
Note: After running the TomTom Clear Flash tool you may need to activate your map again. You need your Product Code card to activate your map
Where will I find this Product Code card they talk about ?
Is it something written down somewhere in all the bumph that was in the box when I brought my 730T ?
Soft Reset - I am still none the wiser as to what that is from your description ( I realise that it is probably me being a numpty ) but can you explain in laymans terms how I do one on my 730T.
Thanks again !................................................................this better bl##dy work after all this messing about. _________________ Keith
dhn Frequent Visitor
Posted: Mon Dec 07, 2009 10:12 pm Post subject: |
In fact, Andy.....
TomTom refers to a 'pin reset' as a 'soft reset' (I guess that includes holding the power button for those models without a dedicated reset hole)
TT refers to a 'hard reset' as 'restore factory settings'.
Clear Flash is just, well, Clear Flash ... _________________ David |
Posted: Mon Dec 07, 2009 10:24 pm Post subject: |
Fair point!
Don't worry about the map activation bit, that is for older models.
The Clearflash tool doesn't delete any files from your 730.
As for the soft (or hard in TT speak) reset, it is normally on the last page of Change Preferences - probably called Reset factory settings. This will clear all of your favourites, home address and recent destinations as well as language and voice settings etc. |
Posted: Mon Dec 07, 2009 10:35 pm Post subject: |
AndyVaughan wrote: | Fair point!
Thanks for the help gents !
I am going to give it another go.
Will try a couple of Clearflashes then a couple of ' pin in hole ' resets and see how I get on.
Really could do with staying away from the hard TT reset if I can help it as that will mean a fair amount of work to get back to where I am.
A thought as I type this , would doing a hard TT reset remove all of my PGSPW speed camera information ?
Because if it does I am DEFINITELY going to give it a miss. _________________ Keith
Andy_P Pocket GPS Moderator
Posted: Tue Dec 08, 2009 1:36 pm Post subject: |
Not really best described as "hard" and "soft" reset.
I would say:
Reset (a paperclip underneath or hold the power button) . Basically just restarts the program. Doesn't change any settings.
"Return to Factory settings" (from within the software menu) -
From an old topic of mine, here's what a "Return to factory setings does:
Quote: | A "Return to Factory Settings" forgets or resets:
Language
Left/Right Handedness
Miles/Km
Clock format
Asks for correct time but seems to remember it.
Voice
Map selected
Map Colour scheme (cannot select a custom scheme the first time!)
MapShare joining
Status Bar preferences
Volume Preferences
Street Name Preferences
Keyboard Preferences
Planning Preferences
Music Preferences
Battery saving preferences (this is where "shutdown on loss of power" is)
Hide tips setting
User name and password for the Plus services
Car symbol
Quick menu preferences.
It also forgets for the current map:
Home Location
Recent Destinations
POI Warnings
Itineraries
Map Share corrections
It seems to remember:
Safety Preferences
User POI's themselves (the files are not deleted. In fact it comes back with them ALL selected to show on map)
Brightness Preferences
Speaker Preferences
Start up and shutdown screen
So that's quite a lot to re-do! |
Posted: Tue Dec 08, 2009 8:05 pm Post subject: |
True, my descriptions weren't brilliant, but my thought process was that a hard reset was like a cold boot of a PC, otherwise a stnadard power down is really like Sleep or Hibernate on a PC.
A soft reset is resetting all of the software settings.
Anyway, by now it should be as clear as mud which is which |
Posted: Tue Dec 08, 2009 8:07 pm Post subject: |
Really could do with staying away from the hard TT reset if I can help it as that will mean a fair amount of work to get back to where I am. |
If you aren't prepared to risk having to wipe your TT and having to reset to factory defaults then my advice is stay clear of experimenting with alternative Navcores and stick with what HOME offers up.
Then again, HOME has a habit of wiping all of your favourites on map upgrades every now and then ........ |
MrT Frequent Visitor
Posted: Wed Dec 09, 2009 8:40 am Post subject: |
One feature I have noticed with the 9 NC on the 940 is that in map view you can additionally choose if your selected to show POIs are shown in 2D & 3D maps. If shown in neither 2D or 3D the warn when near POI function seems intermittant, sometimes it they all work and sometimes they all don't.
At the moment as long as the Live Services servers are running OK it otherwise is quite useable. It still has the old bugs of the screen not updating from time to time and when you go through the menu to HD Traffic the unremovable reminder that you could also click the traffic bar. I like the way it also shows the extra delay due to normal busy traffic from IQ routes. _________________ Drivelux |
Posted: Wed Dec 09, 2009 8:36 pm Post subject: |
Yep - the new interface is very good, apart from the powerpoint on steroids (stole that from someone else) transitions
I like the new way that traffic and route summaries are displayed - it looks much more modern as the Nav8 interface is getting a little dated now.
Shame that it doesn't appear to be getting rolled out to anything other than x50s at the moment though. |
jbsolutios Occasional Visitor
Posted: Thu Dec 10, 2009 2:58 pm Post subject: |
I too am having the same problem with Navcore 9 on 940: -
Warning: There is something wrong with your SIM card. Please contact TomTom customer support.
Error Code: 1008
Everything else works great though! |
Posted: Thu Dec 10, 2009 3:18 pm Post subject: |
The SIM card error message occurs when you try to access a Live Service when a network connection is not established.
(Is there something wrong with this forum as I am finding TT Live Services easier to use at the minute?) _________________ Drivelux |
