Pocket GPS World :: View topic - which is the best poi and camera add on for tt3
robdeb
PostPosted: Sun Jul 11, 2004 5:25 pm    Post subject: which is the best poi and camera add on for tt3 Reply with quote
what is the best poi and camera add on for tt3 and does it work
Parky
PostPosted: Sun Jul 11, 2004 6:36 pm    Post subject: Reply with quote
For me the best is Checkpoint (Link attached) http://www.pocketgpsworld.com/modules.php?name=Downloads&d_op=getit&lid=5 version 2 works best apparently. I used to have POI Warner until I had to hard reset, and couldn't find my re-activation codes. I find Checkpoint works just as well as POI Warner
Alan
robdeb
PostPosted: Sun Jul 11, 2004 7:32 pm    Post subject: Reply with quote
does it have poi and camera included any problems installing it
thanks
Parky
PostPosted: Mon Jul 12, 2004 8:37 am    Post subject: Reply with quote
First download the speed camera database following this linkhttp://www.pocketgpsworld.com/modules.php?name=Downloads&d_op=getit&lid=60
You need to unzip this file, then copy the two files which are not excel spread sheets (POI Binary OVS, and Bitmap image BMP) into your folder where you saved your map (usually your storage card).
Once these are copied, open TT and in the properties screen under POI you will find pocketgps UK sc listed, just tick in the box and you wil be able to see the cameras in Navigator.
Install Checkpoint from the previous link, and set up the parameters within Checkpoint to monitor the Speed Camera Database. It is a fairly easy install and an intuitive piece of software to follow.
A further piece of software you may want to get is POI Edit http://www.dnote.nl/pda/poi/PoiEdit/downloads.htm this software allows you to sync your POI automatically, and saves you having to copy the files to your storage card manually.
robdeb
PostPosted: Mon Jul 12, 2004 3:55 pm    Post subject: EXCEL SHEETS Reply with quote
what are the excel sheets for that come with the sc updated list
do you know of any software for poi as in Mc donalds and that sort of thing
thanks again Rob
Parky
PostPosted: Mon Jul 12, 2004 4:30 pm    Post subject: Reply with quote
The xls file is for use with CoPilot software, and the csv file is for use with Autoroute/MapPoint software.
Don't really understand what you mean in the second part of your question, however if you follow this link http://www.pocketgpsworld.com/tomtompoi.php you will see under United Kingdom more than 100 POI to choose from that you can use.
22.063 (19 Jun 24)
