Pocket GPS World :: View topic - Need to show tenths on iGO 8 Trip Computer screens
alab
PostPosted: Mon Oct 19, 2009 7:11 pm    Post subject: Need to show tenths on iGO 8 Trip Computer screens Reply with quote
Hello.
Does anyone know how to have Tenths of a mile (0.1, 0.2, etc.) show on the Trip Computer screens over and above 20 miles. Tenths are displayed up to 20 miles, but then it only displays whole mile values. It is very frustrating when attempting to follow detailed instructions over a reasonable distance, for example on a rally.
Hopefully there is something simple to add into the SYS file in the IGO8 directory (folder).
I am running iGO 8.3.2.97313
Was Typhoon MyGuide 7000 XL with AA Navigator then iGO 2006+.
Then MiTAC Mio P560 with iGO 8, then Samsung Galaxy S3 with iGO MyWay 8.4.3.179971, then Samsung Galaxy S5 with Sygic 15.2.5.
Now Galaxy S8+ with Sygic 16, Google Maps beta and Here (we g
alab
PostPosted: Wed Dec 02, 2009 10:03 pm    Post subject: Reply with quote
OK. After a month and a half of silence, is it possible that one of these "skin" things may have a solution to keeping the decimal point in the Total Distance field past the first 19 miles?
Any help please will be gratefully received.
Thanks in advance.
PostPosted: Thu Dec 03, 2009 9:14 am    Post subject: Reply with quote
I'll try to remember to have a look in my skin later to see if the tenths is deliberately suppressed ove 20miles
alab
PostPosted: Thu Dec 03, 2009 10:39 am    Post subject: Reply with quote
Many thanks.
PostPosted: Thu Dec 03, 2009 3:55 pm    Post subject: Reply with quote
The line that sets the size, position etc of the total distance is in the active data.zip file
In my case its at Igo8\content\skin\TT33.zip
Within my zip file it's at TT33.zip\ui_igo8\320_240\ui\tripcomputer_320_240.ui
The line itself is
~TEXT txt_trip_totaldist template=txt_tripcomp_value x=8 y=158 text="0.0" textmodel_wstr="other.tripcomputer.distance_total.number_text" fixedwidthnumbers=1 fontsize=30~
(~ is open and close triangular bracket)
Your X,y and fontsize values will probably be different.
The distance comes from "other.tripcomputer.distance_total.number_text"
I have tried altering the 'fixedwidthnumbers' parameters but this makes no difference. I expect that the 'other.tripcomputer.distance_total.number_text' is formatted by IGO to behave as you say.
I wonder if Linknet is on the side, he can possibly shed more light on this.
OK, a lot of typing, but no solution, sorry. Confused
linknet
PostPosted: Thu Dec 03, 2009 5:01 pm    Post subject: Reply with quote
I expect that the
That's exactly right, it's formatted internally by iGO in the executable, so no chance of changing it.
You could try ".full_text" instead of ".number_text" but I wouldn't be too hopeful.
Another point, just to throw a spanner in the works, is how accurate is the trip distance in the first place. To display increments of 0.1ml after 20mls may be pointless if the uncertainty in the distance is more than that.
Regards
linknet
PostPosted: Thu Dec 03, 2009 5:02 pm    Post subject: Reply with quote
Thanks for the confirmation linknet. I suspected that you woiuld be lurking an IGO topic Very Happy
Suspect that it would be a good experiment, but how do you accurately measure the distance to start with?? Over a longish distance route I suppose
linknet
PostPosted: Fri Dec 04, 2009 10:51 am    Post subject: Reply with quote
Suspect that it would be a good experiment, but how do you accurately measure the distance to start with?? Over a longish distance route I suppose.
Perhaps over a long straight road with distance markers, but that would probably show it to be quite accurate. The errors are most likely to occur on twisty roads as iGO takes the straight line distance between each GPS point and adds these up (assumption) rather than taking the actual distance around each curve.
linknet
linknet
PostPosted: Fri Dec 04, 2009 11:02 am    Post subject: Reply with quote
I'ts possible to show the underlying value in metres without formatting like this:
Code:
Original:
{TEXT   txt_trip_totaldist template=txt_tripcomp_value x=8   y=168 text="0.0" textmodel_wstr="other.tripcomputer.distance_total.number_text" fixedwidthnumbers=1 }
{TEXT   txt_trip_totaldistlbl template=txt_tripcomp_unit x=78  y=176 w=23 text="km" textmodel_wstr="other.tripcomputer.distance_total.unit_text" }
Code:
Replace with:
{TEXT   txt_trip_totaldist template=txt_tripcomp_value x=8   y=168 text="0"   textmodel_wstr="other.tripcomputer.distance_total.value"       fixedwidthnumbers=1 }
{TEXT   txt_trip_totaldistlbl template=txt_tripcomp_unit x=78  y=176 w=23 text="m" }
(replace curly brackets with arrow brackets)
That gives the value in metres irrespective of the regional settings, you just need a handy pocket calculator with you.
linknet
PostPosted: Fri Dec 04, 2009 1:22 pm    Post subject: Reply with quote
Or some type of lookup table Very Happy Not too practical to conv M to Miles though Confused
linknet
PostPosted: Fri Dec 04, 2009 2:07 pm    Post subject: Reply with quote
I seem to remember something about lookup tables before, wasn't that one of your projects. Wink
linknet
alab
PostPosted: Mon Dec 07, 2009 11:11 am    Post subject: Reply with quote
Thanks guys for this.
I take the point on accuracy and understand that when the sat nav follows an arc the calculated distance is the chord of that arc and not the circumference. Also that the accuracy is dependent on the quality of the satellite fixes, the speed of travel and the beat frequency of the satellite fixes. Thus, slow speed, good satellite fix and frequent beats gives the more accurate calculation.
Out of interest, I followed a route calculated by the sat nav to be 20 miles distance (over fairly twisting roads) and set the trip at the beginning and checked at the end. The trip distance showed 20 miles (but that could be 20.9 miles rounded). I will try with a shorter and much longer trip to see what differences may come into play.
I will try the metre option as soon as I can pluck up the courage to start fiddling with the zip file – I have unpacked it and found the file. For the novice, does changing the active data.zip file require iGO to be unloaded and reloaded, or will the new data.zip be picked up automatically next time the s/w is called?
linknet
PostPosted: Mon Dec 07, 2009 12:13 pm    Post subject: Reply with quote
As long as you keep a backup of the original data.zip you can't do any harm, the modified data.zip will be picked up the next time you start iGO. If you have made a mistake iGO will probably throw up an error and exit, but restoring the original data.zip will restore everything back to normal. You need to edit the file corresponding to the resolution(s) you are using, the example above assumes a 320x240 resolution but that may be different for your device.
linknet
PostPosted: Mon Dec 07, 2009 9:12 pm    Post subject: Reply with quote
Yes, but you cracked that one (meters to ft {Plus or minus mount everest}) Very Happy Very Happy
PostPosted: Mon Dec 07, 2009 9:18 pm    Post subject: Reply with quote
I don't think so otherwise the trip would always under-read, and what happens if you drive a circular (ish) route?
My guess is that the trip distance is updated once a second (GPS update interval) adding the distance that you have travelled in the last second to the running total.
22.124 (26 Dec 24)
