Pocket GPS World :: View topic - Voice control lost
Voice control lost
playswell
PostPosted: Thu Nov 26, 2009 6:27 am    Post subject: Voice control lost Reply with quote
I appear to have lost my voice control menu, the Mic is missing from the map screen and the icon in the menu id geyed out. Tried the usual hard reset etc same prpblem. Any ideas?
Its a Go 940
Lift Tester/Adjuster
PostPosted: Thu Nov 26, 2009 12:01 pm    Post subject: Reply with quote
I've had this before (or somethng similar ) on a 720. I think a reset AND a return to factory settings (from the menu) fixed it.
Also check you still have the voice conttol files in the current map you're using. "cspeech_GBR.dat...."
playswell
PostPosted: Fri Nov 27, 2009 6:45 am    Post subject: Reply with quote
Excellant advice as usual Andy its all back and working as normal. Many thanks
PostPosted: Fri Nov 27, 2009 8:13 pm    Post subject: Reply with quote
Great!
Wish I knew WHY it fixed it though! Laughing
PostPosted: Fri Nov 27, 2009 8:53 pm    Post subject: Reply with quote
It will more than likely reset the "support_asr.dat" file contents to the value of 1 as this file can become corupted with garbage or a 0 in which case ASR won't work, hitting the restore factory defaults will put this file back to what it should be - This is an educated guess, but I cannot think of anything else a restore option will be able to fix to get this working again - Mike
22.062 (12 Jun 24)
