Darren Frequent Visitor
Posted: Wed Nov 25, 2009 10:00 am Post subject: |
LostMike wrote: | I'm not sure this is necessarily correct. I understand that some of the differences in the "platform software" relate to the hardware on which they run. I believe that the older and newer A10s have different motherboards. |
That is how I understand it. Perhaps not necessarily different motherboards but certainly different code burnt into non-writable memory at least. _________________ Darren Griffin |
daveweth Occasional Visitor
Posted: Wed Nov 25, 2009 10:11 am Post subject: |
I've just noticed on the Satmap webite that the Platform Software Update is available free to Mac users , pending the release of Macsync in a few weeks. http://www.satmap.com/ukstore/index.php?cPath=111_152_153
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Wed Nov 25, 2009 10:12 am Post subject: |
According to their website, the £9.99 card, which IS described as the "Platform Software Upgrade" card, contains Quote: | Software v1.4 contains some features that cannot be downloaded directly to the Active 10 via SatSYNC. As a result we are making these features available to customers on an SD card, for just £9.99. These features include:
1. Hibernate Mode Allows you to put the unit on standby when not used for prolonged periods, meaning that when switched on again, the unit will take just seconds to get a GPS lock. The advantages include extended battery life (up to x hours), as well as much shorter lock times. Please note that the unit will not track your trail whilst on standby.
2. POI and Route Folders Imported routes and POIs can be seen in their respective menus without the need to restart the Active 10.
3. Folder Manipulation Allows folders to be manipulated on the internal storage and SD card via SatSYNC. | Agree a little clarification might still be wise pefore purchsasing. _________________ David
(Navigon 70 Live, Nuvi 360) |
4ndynorfolk Regular Visitor
Posted: Wed Nov 25, 2009 2:15 pm Post subject: |
I've ordered my SD card. I will let you know exactly what it does.
I previously had all sorts of issues caused I think by my copying a load of junk into the file system while trying to get some GPS software to work. Satmap lent me an SD which reflashed the device and fixed it. I figured an SD from which I could restore the device if I ever got in a jam again was worth a tenner. Not to mention the added features.
On a slightly different subject. Has anyone found an EGNOS signal yet? |
Bosun Frequent Visitor
Joined: May 02, 2005 Posts: 473 Location: Wakefield,West Riding of Yorkshire
Posted: Wed Nov 25, 2009 3:17 pm Post subject: |
4ndynorfolk wrote: |
No EGNOS here in sunny West Yorkshire,
Ian |
RavingDave Lifetime Member
Posted: Wed Nov 25, 2009 4:11 pm Post subject: |
Not too sure why the platform upgrade is free for Mac users, but £9.99 for Windows users? Isn't the underlying platform software independent of what type of machine you choose to connect to, after all I guess you could have both a Mac running Macsync and a PC running Satsync and still be able to connect your A10 to both?
If the platform software update comes on an SD card which is plugged straight into the A10, then will there be any difference between the Mac and Windows version? |
Posted: Wed Nov 25, 2009 4:17 pm Post subject: |
I think the issue is that the updater does not work on a mac.
SD card is the only way to install the new version.
Still a bit miffed that I' payng 10 quid. |
Gibbo10 Frequent Visitor
Joined: Sep 21, 2008 Posts: 262 Location: Swindon, Wilts
Posted: Wed Nov 25, 2009 4:22 pm Post subject: |
Bosun wrote: | 4ndynorfolk wrote: |
Ian |
you will probably find that the signal comes and goes but when you get it the gps signal in top right will go blue and your gps accuracy will improve but in wiltshire it doesn't stay around for long |
smashing Occasional Visitor
Posted: Wed Nov 25, 2009 4:30 pm Post subject: |
I seem to have found a nasty bug in the new firmware. If I go into the 'Set trip data' menu then press back or done - the unit hangs with the only solution being to remove the battery. Has happened three times n a row now so not a momentary glitch.
Anyone else getting this problem (or is it just me)?
ETA - a nice fellow at satmap told me to clear all settings again...and it worked. So all's well and it's still a fantastic device.
Posted: Wed Nov 25, 2009 4:34 pm Post subject: |
4ndynorfolk wrote: | I think the issue is that the updater does not work on a mac.
Yep understand that, but the updater on a PC only works for updating the 'main' software to V1.4 - it still doen't allow you to update the Platform software - so a PC user is in exactly the same position as a Mac user as far as platform updates are concerned? |
Posted: Wed Nov 25, 2009 4:42 pm Post subject: |
I'm guessing the the platform update is required to enable SatSYNC for MAC. It is not required for PC users and brings no benefits to them so is not offered?
If you may have cause to sync on both PC & Mac then you would need it. _________________ Darren Griffin |
lucevans Frequent Visitor
Joined: Mar 21, 2007 Posts: 261 Location: Cambridgeshire, UK
Posted: Wed Nov 25, 2009 4:46 pm Post subject: |
Ian |
getting EGNOS here in Cambridgeshire some of the time- mainly via PRN120 -
but I do live at sea level with a pretty unobstructed view of th sky.
I too have ordered the platform upgrade card, so I'll let you all know if it doesn't work for my very old Active 10 (serial number in the low hundreds, so if some older units have different innards, it's probably one of those!) |
Posted: Wed Nov 25, 2009 4:49 pm Post subject: |
Darren wrote: | I'm guessing the the platform update is required to enable SatSYNC for MAC. It is not required for PC users and brings no benefits to them so is not offered?
If you may have cause to sync on both PC & Mac then you would need it. |
...but the $64000 question (or in fact the £9.99 question)....is the SD card for updating the A10 device identical for both Mac and Windows. ie if I get a Mac SD card for free, will it update the platform firmware in exactly the same way as if I had bought a Windows variant? |
Posted: Wed Nov 25, 2009 4:53 pm Post subject: |
smashing wrote: | I seem to have found a nasty bug in the new firmware. If I go into the 'Set trip data' menu then press back or done - the unit hangs with the only solution being to remove the battery. Has happened three times n a row now so not a momentary glitch.
ETA - a nice fellow at satmap told me to clear all settings again...and it worked. So all's well and it's still a fantastic device. |
Had the same problem here, just hung showing a "Loading Info" screen. Pressing "Reset All" at the top of the Trip Log Menu seems to have sorted it. |
Posted: Wed Nov 25, 2009 4:58 pm Post subject: |
I am now getting EGNOS on 102 here in Norfolk.
The signal looks strong but is lost much easier than the gps signals.
Acuracy increased from 3m without to 2m with. Not sure it's worthwile. |
