Pocket GPS World :: View topic - CF CoPilot, 2210 and Bluetooth - Cannot Detect GPS Signal
scunner
PostPosted: Sat Jul 10, 2004 10:20 am    Post subject: CF CoPilot, 2210 and Bluetooth - Cannot Detect GPS Signal Reply with quote
Sorry if this is off topic or just a dumb question, but I've just bought the CF CoPilot 4. Installed the software onto my 2210 (I'm in the UK, but it's a US Ipaq), but the GPS keeps failing with the "Cannot Detect GPS Signal" message.
I have contacted ALK support in the UK, who talked me through how to Autoscan for the correct port. Unfortunately, this always seems to bring up the BT screen (remember I have the CF version of the GPS) and then after about 5 minutes tells me that it can't find anything.
I have been told to use the BTRegTweak utility to disable BT autoconnect facility, but this fails becasue I don't have a registry entry for AUTOCONNECT in my 2210 registry.
I want to play with my new toy, can anyone suggest what to do next - do I just add the registry entry and what is the correct port entry for a 2210 (seems to be either 5 or 8)
IPAQ has ROM version 1.10
scunner
alix776
PostPosted: Sat Jul 10, 2004 10:58 am    Post subject: Reply with quote
try the gps properties screen and then select you gps in the boxes then check the box to turn it on
im not familiar with the copilot system but im asuming it similar to the tomtom gps screen
device Lumia 950 xl
scunner
PostPosted: Sun Jul 11, 2004 4:10 pm    Post subject: Reply with quote
The GPS properties screen only lets you select COM port and speed. Whenever the CF GPS is put in the settings revert to Com7 and 4800 bps.
There is no list of GPS cards or anything like that, the only other thing is the Autoscan button, which when I press it Opens up the Bluetooth Manager screen and then after a wait it fails to find anything.
I've tried the BtRegTweak utility - which initially failed because it couldn't find the Widcomm Registry entry. I have since added the following registry item
\HLKM\SOFTWARE\Widcomm\BtConfig\AutoConnect\0008
Aftre adding this entry, the BtRegTweak utility worked and added the DWORD "BtBrowserEnabled" Value of 1.
Now what happens when I insert the CF card is that I get told that:
New modem detected
and that there are no connections on my device that use this modem. I then informed that I should use either "The Internet" or "Work" to create a new connection.
Tapping either one takes me to the "Make New Connection" screen where all of the modems listed appears to be unchanged from when the CF card was not in my 2210. (These are a) Bluetooth Dial up modem; b) Bluetooth Fax Modem; c) Generic IrDA and d) Hayes Compatible on COM1 (Selected)). Taking the default selected item, and typing in trash into the connection number and sign-on details appears to complete this section.
When I then go to try to scan for the CF GPS card, it still brings up the BT control panel and Browser window - regardless of the BtRegTweak setting used.
(BtRegTweak - Manual sets BtBrowserEnabled to 1 and automatics sets it to 0. Is this correct?)
Any other suggestions on what to do gratefully appreciated.
scunner
scunner
PostPosted: Sun Jul 11, 2004 4:24 pm    Post subject: Reply with quote
DOH! I think that the CF receiver I have is a Version 1 example which is not compatible with WM 2003. Read ALK's FAQ but didn't spot the word "not" in the following sentence
If your CF GPS has a serial number that is not within the range of E31950001 - E31950500 you have a version 1 receiver not compatible with the new operating system.
I'll speak to support tomorrow (Monday) and post back after that.
Thanks for your help.
scunner
scunner
PostPosted: Fri Jul 16, 2004 10:18 pm    Post subject: Reply with quote
Just an update.
Replacing my CoPilot GPS CF card has fixed the problem.
The COM Port had to be manually set to COM7.
Still had to Dismiss the new modem detected message.
Thanks to ALK support.
22.064 (26 Jun 24)
