Pocket GPS World :: View topic - Temporary SPECS Cameras
Eyebeear
PostPosted: Fri Nov 20, 2009 9:03 am    Post subject: Temporary SPECS Cameras Reply with quote
Can we please have the temporary (roadworks) average speed cameras as a separate file?
PostPosted: Fri Nov 20, 2009 9:53 am    Post subject: Reply with quote
Why? What benefit would that bring?
Eyebeear
PostPosted: Fri Nov 20, 2009 10:02 am    Post subject: Reply with quote
The current state of the database is very inaccurate. The cameras are constantly moving and being switched on or off as the roadworks progress.
I would simply prefer not to load them into my device rather than have inaccurate and out of date information.
HP iPAQ 5935 running Nav N Go iGO8
HP iPAQ 5720 running Mapfactor Navigator 9 (Truck)
PostPosted: Fri Nov 20, 2009 10:04 am    Post subject: Reply with quote
My best guess would be so that you don't have to load them and be constantly warned of the tSPECS when it is blindingly obvious that you are in a roadworks Very Happy
But I do appreciate that this would increase the POI categories for some systems. Sad
EDIT: Beaten to it Shocked
PostPosted: Fri Nov 20, 2009 10:16 am    Post subject: Reply with quote
I'd have to take exception with the claim that they are very inaccurate. They are obviously a moving target but they still serve as a useful reminder.
There are huge issues with adding a new file and we would be very reluctant to do so.
PostPosted: Fri Nov 20, 2009 10:26 am    Post subject: Reply with quote
It may be blindingly obvious to you but then traffic lights are blindingly obvious to me but we still have a redlight file.
The database is there to serve as a reminder that there are speed limits and they are possibly even more important in an area where roadworks are under way?
Even though roadworks SPECS move, they don't move that frequently and when they move they may move one section at a time. So the warnings are still useful.
If necessary we can make a splash about the need for more tSPECS reports to ensure we capture the move in a timely manner.
But where I have come across tSPECS which have been inaccurate they have still served a purpose.
Eyebeear
PostPosted: Fri Nov 20, 2009 10:43 am    Post subject: Reply with quote
It was just a thought.
As it seems it would be difficult to produce a separate file, could the tSPECS cameras not be marked as such within the existing SPECS file?
PostPosted: Fri Nov 20, 2009 10:49 am    Post subject: Reply with quote
It may be blindingly obvious to you but then traffic lights are blindingly obvious to me but we still have a redlight file..
My guess was at why the OP wanted a saparate file(s). Borne out by his answer. I also fully agree with you about redlight and Redspeed cams. Very Happy
I think that's a good Idea Very Happy
PostPosted: Fri Nov 20, 2009 10:51 am    Post subject: Reply with quote
They are recorded as tSPECS within the file, what else did you have in mind?
Eyebeear
PostPosted: Fri Nov 20, 2009 11:11 am    Post subject: Reply with quote
How are they marked?
I'm using the .txt files for iGO.
As a long distance LGV driver, I come across a lot of roadworks on our motorways, and I guess that I'm in as good a place as anyone to help clean up the tSPECS data. I shall be doing my best to keep up with them.
PostPosted: Fri Nov 20, 2009 11:16 am    Post subject: Reply with quote
That makes it difficult then, but good choice of software Very Happy
You sound like just the person to have on board as a spotter. Keep up the good work. I see by your 'lifetime' that you have already been busy Very Happy
AliOnHols
PostPosted: Fri Nov 20, 2009 8:44 pm    Post subject: Re: Temporary SPECS Cameras Reply with quote
Eyebeear, Although it may not be possible to have the tSPECS files supplied as a separate file you do not need to extract them from the download if you don't want to. Depending upon the brand of "unZipper" you use, highlight only the zipped files of the cameras you want to to unzip before clicking on the "extract" button. I avoid unzipping and loading mobile cameras onto my TomTom using this method.
Alternatively, unzip all files onto your PC somewhere but transfer across onto your SatNav only the speedcam POI's you require (if iGo allow you to do this).
Garmin Nuvi 2599
SatMap Active 10 & 20.
Eyebeear
PostPosted: Fri Nov 20, 2009 8:56 pm    Post subject: Reply with quote
AliOnHols,
Thanks for the thought, but it is not possible to differentiate between the tSPECS and SPECS data in the .txt files downloadable for iGO. Otherwise I'd not have a problem.
PostPosted: Fri Nov 20, 2009 9:02 pm    Post subject: Re: Temporary SPECS Cameras Reply with quote
How does that work? The tSPECS are in the SPECS file. So he'd have to do without ALL SPECS or is that what you meant?
AliOnHols
PostPosted: Fri Nov 20, 2009 9:40 pm    Post subject: Reply with quote
Eyebeear wrote:
AliOnHols,
Eyebeear, Sorry for the bad advice.
Garmin Nuvi 2599
22.094 (25 Sep 24)
