Pocket GPS World :: View topic - Keep getting logged out
mags97
PostPosted: Sun Nov 15, 2009 10:54 am    Post subject: Keep getting logged out Reply with quote
Have been trying to give Ash camera manager a try. Have given up because I am continually receiving a message on the camera manager icon that I am logged out. Have tried Firefox and Internet Explorer. Any Ideas why?
JockTamsonsBairn
PostPosted: Sun Nov 15, 2009 1:09 pm    Post subject: Reply with quote
Ash10 wrote:
Note that you will need to be logged in to PocketGPSWorld.com in order for Camera Manager to check for updates. This needs to be done using Internet Explorer Sad, although once you've logged in with IE you can go back to using Firefox etc. Smile
If you're not logged in to PocketGPSWorld.com, Camera Manager can't check for updates, and it will let you know accordingly:
Ash does say it has to be IE, but have you updated IE (e.g. to IE8?) since you last had Camera Manager working? If IE8 (I'm on FF), are you still having to use "compatibility mode" to force IE to display the site correctly? Maybe the cookie are different between IE7 & IE8?
Jock
mags97
PostPosted: Sun Nov 15, 2009 3:18 pm    Post subject: logging off Reply with quote
Hi Jock
I have not updated internet ex. since I decided to give camera manager a spin. I used int. Exp. as I had read that there were issues using FF. I have only recently tried to use Camera Manager. I have now logged on with both ie int. Exp. and FF. Would rather use FF only! Do you have probs using FF to access camera manager? and does it stay connected through FF until you log out? thanks for your help
mags97
JockTamsonsBairn
PostPosted: Sun Nov 15, 2009 4:32 pm    Post subject: Re: logging off Reply with quote
mags97 wrote:
Hi Jock
mags97
Ah, I got the impression, from previous posts, that you had been using Camera Manager for more than 6 months, so I presumed that something that had happened recently had stopped it working!
I'm afraid that I can't help much more as I don't use Camera Manager.
As far as the Web Site is concerned, I stay logged in forever using FF.
Jock
dales
PostPosted: Sun Nov 15, 2009 8:33 pm    Post subject: Reply with quote
I use Firefox and Camera Manager all the time. I did have "logged out" problems a month or so ago - perhaps due to the IE update - but all is OK once again.
I read this in the Ash10 help:
In order for Camera Manager to work, you must have logged in to PocketGPSWorld using Internet Explorer - this only needs to be done once, provided that you do not explicitly logout. Note that some internet history/cookie cleaner applications will effectively log you out, so if you are using one make sure that it is configured appropriately.
It doesn't matter if you normally use a different browser to Internet Explorer (eg: Firefox) - once you have logged in to PocketGPSWorld using Internet Explorer, you won't need to touch it again.
So I made sure I did not explicitly log out, whilst in IE, and that seems to have fixed it.
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
mags97
PostPosted: Wed Dec 02, 2009 9:35 pm    Post subject: Reply with quote
Dales.
Many thanks,
Although I did not log out it appears I was being logged out. It could be some security issue regarding Norton or FF. Many thanks for your help.
mags97
22.105 (30 Oct 24)
