TonyD Frequent Visitor
Posted: Fri Nov 13, 2009 12:06 am Post subject: My iPhone TomTom has gone Irish |
All of a sudden TT on my iPhone only knows about Irish destinations, however the map shows the Uk and Ireland. what have I done ? _________________ Tony
(TT940) |
Posted: Fri Nov 13, 2009 12:16 am Post subject: |
Are you using the HelpMe feature? if not try selecting navigate to a postcode and select something local - Mike |
Posted: Fri Nov 13, 2009 12:28 am Post subject: |
mikealder wrote: | Are you using the HelpMe feature? if not try selecting navigate to a postcode and select something local - Mike |
It's not accepting any UK postcodes, it's just as if the UK doesn't exist _________________ Tony
(TT940) |
Posted: Fri Nov 13, 2009 9:10 am Post subject: |
Tap Navigate To/ Postcode and when the screen opens top right there should be a dropdown arrow tap this, next to the area where you type the postcode there should now be a country indicator, if thats not GBR tap it and select United Kingdom - Mike |
Posted: Sat Nov 14, 2009 10:35 am Post subject: |
mikealder wrote: | Tap Navigate To/ Postcode and when the screen opens top right there should be a dropdown arrow tap this, next to the area where you type the postcode there should now be a country indicator, if thats not GBR tap it and select United Kingdom - Mike |
Oops, yes I discovered that just before you posted, silly me.
Thanks. _________________ Tony
(TT940) |
Posted: Sat Nov 14, 2009 10:38 am Post subject: |
That drop arrow annoys the heck out of me as it often needs to be pressed to find a way back from some of the menu selections let alone opening up otherwise hidden items, not very intuative in use which is unusual for TomTom - Mike |
