Pocket GPS World :: View topic - CPL Central
CPL Central
RoyC
PostPosted: Thu Nov 12, 2009 12:26 pm    Post subject: CPL Central Reply with quote
I have been using CPL Central on a laptop with XP and have just bought a new laptop with W7. The new laptop is running the 64 bit version of W7 so I downloaded the appropriate version to the new laptop. It installs fine but when you start it up it fails.
Has anyone else found this ? Is it a known(to ALK) problem? Or has anyone else got it working OK?
Roy
scarymonkey
PostPosted: Thu Nov 12, 2009 12:44 pm    Post subject: Reply with quote
I had one laptop fail and the other worked fine. Never did resolve it until I reloaded the laptop. Worked perfectly then.
RoyC
PostPosted: Thu Nov 12, 2009 1:48 pm    Post subject: Reply with quote
Thanks for that. It is a brand new laptop and this was one of the first apps loaded - I have downloaded it several times and reinstalled but the result is the same.
Roy
BaggieBoy
PostPosted: Thu Nov 12, 2009 4:40 pm    Post subject: Reply with quote
I'm using CoPilot Central 2.0 with Windows 7 64 bit for a while. I recently tried to upgrade to the latest version and found it wouldn't start. I had to uninstall the application and do a clean install before it worked again.
RoyC
PostPosted: Thu Nov 12, 2009 4:51 pm    Post subject: Reply with quote
Baggieboy
Thanks for that - I have done that twice but stilll fails but it is good to know it does work - sme how.
I have reported it to CPL support - will let you know.
Roy
PhilB
PostPosted: Fri Nov 13, 2009 5:47 pm    Post subject: Reply with quote
No problems - I'm running W7 64 bit on a Dell Inspiron 640M and had no problems with the update.
The only problem I've had with it is that it doesn't seem able to download any updates for WinMob or any Live Services for the UK Wink
22.063 (19 Jun 24)
