Pocket GPS World :: View topic - Roadhawk in-car camera GPS and black box system
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 10, 11, 12  Next
shelmo
PostPosted: Thu Nov 12, 2009 11:35 am    Post subject: Reply with quote
BigPerk wrote:
The only thing is I thought someone said there was no date/time stamp on the RH files. Is this right, and if so, would that make it difficult to use for a NIP?
You are right there is no date/time stamp on the file names that it save but all the video images do have it on just make sure that you set it for the right time zone.
PostPosted: Thu Nov 12, 2009 11:37 am    Post subject: Reply with quote
I made the comment about the Filenames not containing the date/time not that the files themselves were not date/time stamped. My unit is out in the car at the moment so I can't check, Nick did I miss something there?
NickG
PostPosted: Thu Nov 12, 2009 11:39 am    Post subject: Reply with quote
It just uses the GPS date/time, so you don't really need to set anything. Despite what it looks like in the viewer - the videos are not actually timestamped graphically - that's just an overlay in the viewer software and does not show up in the exported video.
PostPosted: Thu Nov 12, 2009 11:42 am    Post subject: Reply with quote
But is there an easy way to look back and locate the file that covers a specific date/time?
NickG
PostPosted: Thu Nov 12, 2009 11:46 am    Post subject: Reply with quote
If you look at the raw files on the SD card - then yes. But annoyingly no date/time indicator is present in the viewer's own list of files. I'm going to write to them and ask them to add this in as it would be very useful.
The file names are just serial numbers, but as it's so incredibly easy to rename files and alter the created and modified dates of the file, it's not too important whether they're stamped in this manner anyway, IF the viewer software showed this information. EDIT: By that, I mean that it would be no use from the point of timestamping them from an evidential point of view. It would be useful to us users.
PostPosted: Thu Nov 12, 2009 11:48 am    Post subject: Reply with quote
Ah yes, that was my gripe in the review. Just for ease of admin it would be nice to have the date/time in the file name so they could be located quickly.
PostPosted: Fri Nov 13, 2009 9:19 am    Post subject: Reply with quote
The really really most significant factor for me is the capacity of SDHC cards. In less than an hour's time, I'm setting off to do something like 600 miles round trip. That's an unusually long day for me, but I shall start by driving partly along the road in Bristol where that van driver got his NIP overturned - that means the "evidence" will be perhaps 12 hours old on the card.
I really think this is information which should be available from RH themselves - a table saying 2GB card = 1 hour at top resolution, 2hrs at x etc etc, with all the possible card sizes and resolutions. Can we ask them for it please. I really fancy one of these devices, but if the recording time for 2GB cards is 1 hour, I don't want to know - there has been mention of the supplied 2GB card lasting "days", but from what's being said here now, it doesn't sound anything like even one of my normal days - I don't do school run and a bit of shopping, I do a working day's driving.
PostPosted: Fri Nov 13, 2009 9:39 am    Post subject: Reply with quote
I'll ask.
I really fancy one of these devices, but if the recording time for 2GB cards is 1 hour, I don't want to know - there has been mention of the supplied 2GB card lasting "days", but from what's being said here now, it doesn't sound anything like even one of my normal days.
But if the high quality permanent record is 1hr/2Gb then a 16GB card would give you 8hrs full coverage.
And cards are relatively cheap now but I can appreciate you'd want to be able to record at least a whole working day on one card as a minimum.
There is no need to have the top quality setting though and you could use the option to save only events that you trigger. If you want to lock in an event you just press the hazard button on the unit and that file will be saved.
NickG
PostPosted: Fri Nov 13, 2009 10:11 am    Post subject: Reply with quote
These are designed as low cost consumer 'incident/crash cameras' - not permanent recording systems for professional drivers. If you need something which can record everything permanently, there are probably better solutions out there, but obviously you have to pay a bit more money. The same company that distributes these cameras (dogcamsport.co.uk) do quite a few other types of camera which might suit your needs better.
Don't forget though that 2GB is tiny by modern standards and you can easily put in a 16GB card for about £25.
mostdom
PostPosted: Fri Nov 13, 2009 10:43 am    Post subject: Reply with quote
Part of this discussion goes hand in hand with the recent news article about the van driver getting of a speeding conviction using gps. How fantastic it would be to have peace of mind from a unit like this. Not only could it log your speed but show the camera of mobile speed trap as you pass it, but unless you press the button every time you pass a camera or swap the sd card after it is full, the length of time you can store is limited. If I remember correctly the authorities have up to at least 30 days to inform you of an NIP.
30days x 8hours x 2gb= (anyone got a 480Gb SD card)
I did recently spot a small in car camera capable of high resolution capture with long recording times but no gps for about £200.
Dom
SpikeUK
PostPosted: Fri Nov 13, 2009 10:45 am    Post subject: Reply with quote
I use a T-eye, which is very similar - except that it also has a rear facing camera which records what the driver is doing (protects against accusations that the driver is using mobile phone, etc). So the T-eye has twin cameras, sound, 3 shock sensors, Google Map on playback, conversion to .avi etc. It also has an LED display of the GPS speed you are going at, and an infrared light for illuminating the car interior at night, and a "save incident permanently" button (one minute before & two minutes after incident). The software to view the footage is stored on the card itself, so any computer can be used to view the footage.
There's several videos on You Tube - search for T-eye.
I use an 8 GB SD card, which records the last 10 hours or so of driving.
It would be interesting to see a side by side comparision of the video quality of the Road Hawk and the T-eye, and the distance at which a number plate can be read.
It's a good insurance against those clowns that stop infront of you at roundabouts, then reverse into you and claim that you drove into them. Also useful to be able to go back and review exactly what speed I was going at when I passed that speed camera.
Sorry about all the edits - I keep thinking of more features of this device.
NickG
PostPosted: Fri Nov 13, 2009 10:53 am    Post subject: Reply with quote
If all you're trying to do is validate speeding tickets - you don't need video. You just need a GPS travel recorder. Trying to store 2 weeks of GPS data is a hell of a lot easier than trying to store 2 weeks of video!
Unfortunately, I don't know of anyone that makes a travel recorder which takes SD memory cards (or any type of memory card).
My QStarz only seems to have 16MB (yes megabytes) of RAM and that's only enough for about 9 days of recording at 6 hours per day (~200,000 seconds). Why they can't just let you put a MiniSD card in I really don't know. I want to be able to record 2 weeks of skiing at 1 second intervals. You need 64MB to reliably do that.
PostPosted: Fri Nov 13, 2009 10:58 am    Post subject: Reply with quote
I've got a few dataloggers that use memory cards, one used SD, the other micro-MMC.
PostPosted: Fri Nov 13, 2009 11:00 am    Post subject: Reply with quote
Tried to get one for review but two companies who stocked them both promised review units then failed to deliver so I gave up.
Do T-eye state the video recording resolution and FPS?
mostdom
PostPosted: Fri Nov 13, 2009 11:01 am    Post subject: Reply with quote
I want all my cake to eat. I had been looking at standalone gps data loggers but the idea of including video has been delaying my decision to buy.
Dom
Page 7 of 12
22.062 (12 Jun 24)
