AlanK Regular Visitor
![](modules/Forums/images/avatars/gallery/spider.jpg)
Posted: Sat Nov 07, 2009 6:14 pm Post subject: 540 spoken text and speed cams |
will shortly be putting the database on my 540, the last Go device I had you had to put a bunch of voice files with the same name as the POI file to get spoken alerts (or change some CHK file)
As things have moved on and this has some text to speech thing will I be able to get this to tell me the camera type and speed or do I still need to find and install the voice files? (in which case where are they these days?)
Cheers! |
Robin2 Lifetime Member
Posted: Sat Nov 07, 2009 9:15 pm Post subject: |
Yes, when setting up the options for audible warnings for each camera type, you can select TTS and type in your own message. I did this a couple of firmware releases back because the downloadable recorded messages were never the same volume as the navigation instructions. I have stayed with it and much prefer it to the various bongs available in the menu
I have typed warnings like Gatso 30 30, Mobile 50 50 etc
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Sat Nov 07, 2009 10:37 pm Post subject: |
Here's the link to the OGG files - spoken warnings. I find them far preferable to typing your own, which can take an awful lot of effort to get right (adding spaces and punctuation to get the right result).
Also check out the camera icons here. Read all the interesting stuff about them before proceeding. _________________ Dennis
Two of them are obesiting!! |
Andy_P Pocket GPS Moderator
Posted: Tue Nov 10, 2009 2:50 am Post subject: |
Robin2 wrote: | I did this a couple of firmware releases back because the downloadable recorded messages were never the same volume as the navigation instructions. |
If you use a "real" voice for navigation instructions, the recorded warnings match in volume very well.
But unfortunately, TomTom in their wisdom made the computer/TTS voices *louder* than their own recorded voices, and never gave us any individual volume controls; so if you adjust the volume to a comfortable level for a TTS navigation voice, the warnings will always be a little bit quieter. |
Posted: Tue Nov 10, 2009 1:17 pm Post subject: |
cheers guys
I noticed the X2 BMP in the downloaded file so that makes a bit more sense now, if I understand it correctly these will display be default rather than me having to do anything else (unless I wanted a different Icon set
As for the voices, I only set up one last night and noticed you could type your own or it could read the name of the file so will see how that sounds, certainly rather than type my own I will probably use the downloadable voices and see how the volume compares.
Not totally hooked on the compute voice reading out street names at moment so may go back to standard TT voices. |
Posted: Tue Nov 10, 2009 8:51 pm Post subject: |
Ahwell, Started to like the street names being read out for me and whatever I choose if I want to retain voice control it is going to be the overly loud computer voice at some point.
This means that as described above the spoken POI warnings downloaded from here are a bit on the quiete side
What kind of punctuation/formating did you use to get the the computer warning voice to sound a bit better. Quite happy with just Gatso 30 Gatso 30 but could do with actually being able to hear her say "Gatso" rather than gt-o and how do I get a pause between the two?
Slght improvement with "Gats-So 30" but still some way off... |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Nov 10, 2009 9:06 pm Post subject: |
Try adding a couple of spaces or a comma or a full stop, you will need to play around with these and possibly combinations of them to get the desired effect you want - Mike |
Posted: Tue Nov 10, 2009 9:58 pm Post subject: |
AlanK wrote: | This means that as described above the spoken POI warnings downloaded from here are a bit on the quiete side ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Have you tried Liz Whitaker with LOUD siren - knocks yer sox off, I love it. ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Dennis
Posted: Wed Nov 11, 2009 9:18 am Post subject: |
oops, didn't scroll far enough down the page (and also thought it was Vik that had the sirens)
Will try them tonight, cheers!
ps - spaces, commas and full stops made not a damn bit of difference to space out the two computer voices warnings. |
Posted: Wed Nov 11, 2009 9:24 am Post subject: |
AlanK wrote: | ps - spaces, commas and full stops made not a damn bit of difference to space out the two computer voices warnings. |
It certainly used to work with the old Loquendo files installed to the 910, to be honest I have used OGG files since and just assumed the spaces etc would still work - Mike |
GerryC Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/web.jpg)
Posted: Wed Nov 11, 2009 10:03 am Post subject: |
AlanK wrote: | What kind of punctuation/formating did you use to get the the computer warning voice to sound a bit better. Quite happy with just Gatso 30 Gatso 30 but could do with actually being able to hear her say "Gatso" rather than gt-o and how do I get a pause between the two?
I gave up trying to get Kate to say gatso and went with "camera" in the end. "Camera! 30!" or "Camera. 30." should give good results. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Anita Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/animal_duck.jpg)
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Wed Nov 11, 2009 12:19 pm Post subject: |
GerryC wrote: | I gave up trying to get Kate to say gatso and went with "camera" in the end. |
For my South African cameras I found putting an "h" on the end improved the pronunciation on my 720, and "Gatsoh,,,100" gives a perfectly acceptable rendition, with the commas spacing it out nicely. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Wed Nov 11, 2009 12:22 pm Post subject: |
I also found "Gats~so" was not too bad, will try with and h and add even more commas to try and get a break between the two warnings. |
EricWB Frequent Visitor
Posted: Fri Nov 13, 2009 11:28 am Post subject: |
Have just tried setting up my newly aquired TT520 using the very latest download file for Kates computer voice and typed in something like "Warning Gatso 30 Miles Per Hour" it seems to reasonably OK to me at least using the demo. I will see how it sounds for real when I next go out in the car. |
Posted: Sat Nov 14, 2009 10:41 am Post subject: |
EricWB wrote: | Have just tried setting up my newly aquired TT520 using the very latest download file for Kates computer voice and typed in something like "Warning Gatso 30 Miles Per Hour" it seems to reasonably OK to me at least using the demo. I will see how it sounds for real when I next go out in the car. |
How is this different from the Liz Whitaker warnings (Except that the Liz ones are actually pre-recorded clear human voice, without computer TTS concerns or spending half a day typing the words)? _________________ Dennis
