standarren Occasional Visitor
Posted: Tue Jul 07, 2009 11:05 am Post subject: navman icn 550 difficult to turn on |
hi guys i have a navman icn 550 i went to put it on the other day but for some reason it didnt want to no i carried on driving then suddenly it came on it was plugged into the charger the red light was on to indicate it was charging
i pulled over to insert the directions after aroung 30 seconds it went off again i've checked the status of the battery and it says its 0% charge it was always pretty bad but i thought that if it was plugged into the charger it would still power on also i've tried to take a peak at the battery inside but not sure how to get into it question is should i replace with new battery or is it at the end of its life |
CaptainDrift Regular Visitor
Posted: Tue Jul 07, 2009 5:20 pm Post subject: |
Have you charged it from a mains charger?
If left overnight will the battery reach 100% |
Posted: Tue Jul 07, 2009 6:50 pm Post subject: |
hi mate just done that its at 100% now but decreases is it the inferia charger i bought regards daz |
flinta Occasional Visitor
Posted: Fri Aug 28, 2009 1:22 pm Post subject: How to open the unit |
The batteries will deteriorate over time and may need replacing if they will not hold the charge. The 4 screws that hold the unit together are accessable from the rear of the unit but may be hidden by small plastic discs. Once removed slowly tease the unit by apart by using your thumb nail between the two halves ensuring that any memory card installed is removed first along with the stylus. The battery is the black item you can see when you open the unit |
trekkertrekker Occasional Visitor
Posted: Wed Oct 21, 2009 1:01 pm Post subject: navman 550 |
If anyone can help on this thene be grateful.....My unit went dead so I followed the instructions below took it apart carefully and replaced battery.
Put it on mains charger till unit turned green and came on .....However I cannot get past the screensaver and on linking it to the computer it says it has the maps etc in it but i cant get to them.....Any ideas please ....Thanks trekkertrekker |
