Pocket GPS World :: View topic - Single Speed Camera Warning Garmin Nuvi
beemabeast
PostPosted: Sat Sep 05, 2009 4:25 pm    Post subject: Single Speed Camera Warning Garmin Nuvi Reply with quote
Hi all,
Can anyone help me I have a garmin nuvi200w not a massive problem as everything works as advertised, I have the PGPSW speed camera database active on the unit but regardless of whether I use garmins or PGPSW's it gives me a warning when approaching a speed camera but carries on bleeping which becomes quite annoying I would be happy with just a SINGLE BEEP and that is it.
Has anyone got any tips on how to configure the POI loader or any other settings to acheive this.
Thanks in Advance.
Dean.
PostPosted: Sat Sep 05, 2009 5:42 pm    Post subject: Reply with quote
Can't do anything with POILoader but take a look at ASH10's Camera Manager which is a sticky in the Garmin forum.
This allows much greater control over the alerts etc
beemabeast
PostPosted: Sat Sep 05, 2009 7:23 pm    Post subject: Reply with quote
Cheers Darren, that looks like the sort of thing I am after. Very Happy
dales
PostPosted: Sat Sep 05, 2009 8:15 pm    Post subject: Reply with quote
Also, if it's anything like my 255WT, you could try Tools...Settings...Proximity Points...Change...Audio, and then select Single Tone rather than Continuous Tone.
Dales.
beemabeast
PostPosted: Sat Sep 05, 2009 8:22 pm    Post subject: Reply with quote
Dales.
Thanks Dale the 200W only has the option for main volume also to select or deselect custom POI's ie speed cams alerts ON or OFF pretty basic. I tried Sticky's Camera Manager though and it works a dream I have only tried it on sim mode but looks good.
Cheers for help guy's.
johnfgolding
PostPosted: Thu Oct 15, 2009 12:05 pm    Post subject: Reply with quote
I have noticed recently that my warning text message has changed from a simple camera warning with speed to be more complex with what appears the camera number and the last two digits indicate the speed. (I do also get the speed icon up).
Is there any way I can get the simple message back?
PostPosted: Thu Oct 15, 2009 12:28 pm    Post subject: Reply with quote
johnfgolding wrote:
Is there any way I can get the sim,ple message back?
hi, have you started using camera manager? if so then this is a 'side effect' of the 'always show icon' setting.
johnfgolding
PostPosted: Thu Oct 15, 2009 12:34 pm    Post subject: Reply with quote
Hi I assume you mean Ash's software. Yes I have.
So is there anything I can do apart from not using it.
PostPosted: Thu Oct 15, 2009 1:24 pm    Post subject: Reply with quote
yep - you can turn off the 'always show icons' option. i'm pretty certain that the nuvi 200 alway shows the icons anyway regardless of speed!
the option was added, if i remember correctly to allow older units to show the icon all the time instead of just when you were at the speed limit!
