Pocket GPS World :: View topic - Speed Limits on A186
BrianCollison
PostPosted: Mon Oct 12, 2009 1:13 am    Post subject: Speed Limits on A186 Reply with quote
On my TomTom 520 the speed limits shown are wrong on the A186 it is showing a speed limit of 60mph when it is actually 40mph, this is a new section of road between Earsdon road (west end) and Earsdon road (East end), this road bypasses Shiremoor, it has always been 40mph since it opened, but since I had an update it changed to 60mph on my 520.
Brian
PostPosted: Mon Oct 12, 2009 1:27 am    Post subject: Reply with quote
You can change it back using MapShare
Just make sure you only select the sections of road that you want to change.
falkirk81
PostPosted: Mon Oct 12, 2009 9:29 am    Post subject: Reply with quote
Hi, I know the road in question as I drive it regularly for work. It has been 40mph since opening, but it is possible to correct it back to 40mph. A bit fiddly to select only the right bits, but it is possible!
Steven
BrianCollison
PostPosted: Mon Oct 12, 2009 10:20 am    Post subject: Speed Limits on A186 Reply with quote
I managed to change it, but one section of that road changes to 50mph and I cannot separate that section to put in the different speed limit, as it highlights the whole length of that road.
Brian
falkirk81
PostPosted: Mon Oct 12, 2009 10:41 am    Post subject: Reply with quote
You have to carefully edit the selected roads. It does automatically select part of the 50mph zone if I remember correctly. Use the edit function to select only the 40mph bits!
PostPosted: Mon Oct 12, 2009 10:49 am    Post subject: Reply with quote
Try a look at my description how to do it HERE. Not that I should be encouraging you, but I'm feeling less grumpy this morning. Very Happy
BrianCollison
PostPosted: Mon Oct 12, 2009 12:53 pm    Post subject: Speed Limits on A186 Reply with quote
Managed it, as you say a little fiddly but it worked, thanks very much for your help.
Brian
