stephengreycollins Occasional Visitor
Posted: Fri Oct 09, 2009 4:50 pm Post subject: nokia n95 8gb - masters and pmobiles? |
just installed speedcam application on my n95, downloaded and installed the current pocket gpsworld database, renamed the file and it works fine, however there is another file, masters and pmobile, what do i do with it. also there is a bmp icon where do i copy that to. thanks |
Darren Frequent Visitor
Posted: Fri Oct 09, 2009 6:26 pm Post subject: |
pMobiles are 'Provisional' i.e. unverified mobiles. Speedcam can only use one file at a time so you can either merge the contents of the pMobile file into the pocketgps_uk_sc.txt file or ignore it.
There is no 'Masters' file in our download?
Speedcam does not use the .bmp icon files. _________________ Darren Griffin |
Posted: Fri Oct 09, 2009 7:16 pm Post subject: |
thanks for clearing up the .bmp question.
my download: pgpsw-speed-cams-QDbha contains 4 txt files, one of them being: pocketgps_uk_masters_pmobile_ this i now understand to be the provisional cameras file.
thanks for your help |
Posted: Fri Oct 09, 2009 7:21 pm Post subject: |
stephengreycollins wrote: | my download: pgpsw-speed-cams-QDbha contains 4 txt files, one of them being: pocketgps_uk_masters_pmobile_ this i now understand to be the provisional cameras file. |
Ah yes, apols, the filename was truncated in my finder view and that bit was obscured.
I'm now wondering why we use the 'masters' name in that release! _________________ Darren Griffin |
Posted: Fri Oct 09, 2009 7:26 pm Post subject: |
Ok, checked. The masters_and_pmobile file is ALL the cameras including unverified pMobiles as well.
Some people choose not to install the pMobiles, so use the other file. If you are happy to have the whole lot inc pMobiles, you install the masters_and_pmobile file instead.
It's done like this for Nokia because you can only have on file installed. Other systems can have loads so they are kept separate for other devices.
Sorry for the confusion but we've both learned something now! _________________ Darren Griffin |
bobbycfc Occasional Visitor
Posted: Mon Dec 07, 2009 9:13 pm Post subject: Re: nokia n95 8gb - masters and pmobiles? |
stephengreycollins wrote: | just installed speedcam application on my n95, downloaded and installed the current pocket gpsworld database, renamed the file and it works fine, however there is another file, masters and pmobile, what do i do with it. also there is a bmp icon where do i copy that to. thanks |
Hi there, I see you have managed to do this with the Nokia N95 8GB. Any chance of explaining to me how to do it? I have downloaded the file ok but the support sheet advises about registering with sybian and getting your IMEI number etc and its all too complicated for me!
Can you tell me if there is an easy way to do this? Also are you using with OVI maps or a different route planner? |
