Pocket GPS World :: View topic - nuvi 1490t touchscreen finger-scrolling problems
cdmackay
PostPosted: Fri Oct 02, 2009 1:00 am    Post subject: nuvi 1490t touchscreen finger-scrolling problems Reply with quote
anyone else have a 1490t (or similar, eg 12/13/14/16 series) and having problems with the touchscreen?
Specifically finger-scrolling: I find it almost impossible to control. The map either doesn't move, moves about randomly, or does nothign then leaps in the wrong direction.
Garmin say it's a fault and I'm sending it back tomorrow, but my friend has just bought a new one from Amazon today and, although it's better than mine, it's not perfect in this regard either.
anyone else seeing this? or can confirm they have a similar model and are definietly not having problems finger-dragging the map around?
thanks much...
darrengsaw
PostPosted: Mon Oct 05, 2009 7:10 pm    Post subject: Reply with quote
I have a 1310, and I know the problem you mean, bizarrely I have got used to it now, it was totally different to my 255, I actually quite like it now.
Seems to work best if you use a finger nail rather than a finger tip. It does seem to be slightly better with the latest firmware, though there is no mention of any touch screen issues in the release notes.
cdmackay
PostPosted: Mon Oct 05, 2009 8:58 pm    Post subject: Reply with quote
thanks; using a fingernail worked well, albeit also leaving marks on the screen (which did wipe off).
even better, I've just discovered, is using a stylus designed for a touchscreen device: works almost perfectly now.
I'll still send mine back to Garmin, though, as my friend's still seems much better (both with 3.00 firmware).
thanks again.
BigPerk
PostPosted: Wed Oct 07, 2009 12:42 pm    Post subject: Reply with quote
Your satnav hasn't got a 'calibrate screen' function in the control settings has it? If it has, this might enable you to adjust the sensitivity of the screen.
(Navigon 70 Live, Nuvi 360)
cdmackay
PostPosted: Wed Oct 07, 2009 3:34 pm    Post subject: Reply with quote
thanks, and apols, I should have said: that was the first thing I tried, and also the first thing that Garmin suggested Smile
We had a good test today, with my 1490t (one of the first to ship) and his (arrived last week); his is *much* better.
The scrolling is much better, but still very far from perfect, and his shows no signs of another problem I have, which is regularly delays in re-drawing the screeen.
Yet we both have 1490t running the latest 3.00 firmware; his shipped that way, mine upgraded.
I will send mine back to Garmin tomorrow, and we'll see.
thanks again.
cdmackay
PostPosted: Mon Oct 19, 2009 5:56 pm    Post subject: Reply with quote
I got a replacement from Garmin. Very quick turnaround (couple of days), brand-new retail-boxed unit with all accessories, even though I only sent back the GPS itself.
Also, *everything* correctly updated in myGarmin for the new unit. Can't fault the level of service, certainly.
However, both the scrolling problem, and the other problem I reported (slow redrawing) are still present in the brand-new replacement. However, both problems are certainly better than they were.
Garmin today told me that slow redrawing was expected, and didn't comment on the continued touchscreen issues.
I suspect this is as good as it gets, until I switch to Navigon, which I am getting very close to doing.
Now engaged in a discussion with Garmin about why I get no traffic icon at all, sometimes, when the receiver is connected. Apparently this does not mean "no signal", as that's what the (undocumented) grey icon is for.
22.063 (19 Jun 24)
