Pocket GPS World :: View topic - Text to speech and voice input gone.
mrfreeze
PostPosted: Tue Oct 06, 2009 6:50 pm    Post subject: Text to speech and voice input gone. Reply with quote
I had to do a new install to my 720.
I have got backups but not with me at the momnet.
I just reformated my drive and then let TThome reinstall a new application.
Luckily i had a backup of my map on an sd card so that's all ok and working again.
However i don't have speech input or text to speech for directions.
Is there some more files that i'm missing, if so where could i get them from?
Again i do have backup's but they're not available at the mo.
Thanks for any help
Go 720 v8.351 GPS v1.20 Boot 5.5120
Kate v710 UK & ROI v850.2781
Go 920 v8.351 GPS v1.20 Boot 5.5120
dhn
PostPosted: Tue Oct 06, 2009 6:54 pm    Post subject: Reply with quote
You need some cspeechXX.dat files in the specific map folder (where XX = country like GB) and you need a text file called support_asr.dat with nothing but a 1 in it in the asr folder.
Try now, if the icons are still greyed out, navigate to--city--and make sure you've selected the GB map in the next screen top right.
Try now.
mrfreeze
PostPosted: Tue Oct 06, 2009 7:54 pm    Post subject: Reply with quote
Hi David,
Thanks,
I had the cspeech files but i didn't have the support_asr.dat file.
I lifted this from my wifes and now i have speech input ok.
Just done a quick route demo and it doesn't seem like i have the text to speech for street names.
Any ideas?
PostPosted: Tue Oct 06, 2009 8:18 pm    Post subject: Reply with quote
Change Preferences/ Voice preferences/ Switch voice and make sure the selected voice has the words "Computer voice" in the top right corner of the picture (Kate and Simon are the two UK voices) - Mike
dhn
PostPosted: Tue Oct 06, 2009 8:45 pm    Post subject: Reply with quote
Also remember that the demo won't use a computer voice or any voice if the speed is set for greater than 400% (with latest applications). Used to be 200%.
mrfreeze
PostPosted: Tue Oct 06, 2009 8:54 pm    Post subject: Reply with quote
Hi Mike,
Yes i still have Kate 7.10 same as i had before.
David,
I tried the demo at 100% to check.
I will test it tomorrow and see if it work in real time.
Thanks to both for your help.
dhn
PostPosted: Tue Oct 06, 2009 9:57 pm    Post subject: Reply with quote
You may wish to do a reset of the unit. May not help but won't hurt (you might have to reset the time, that's all).
PostPosted: Tue Oct 06, 2009 11:47 pm    Post subject: Reply with quote
I went through a phase of losing TTS voices ocassionally.
Old copies of MapSettings.cfg can stop the computer voices working so this could well be the problem if you've downloaded a new version of Navcore but used a backup map folder including the .cfg file from an older version.
Delete that file (it will create a new, empty one on next boot up) and also do a return to factory settings.
mrfreeze
PostPosted: Wed Oct 07, 2009 7:13 pm    Post subject: Reply with quote
Update:
Yes it worked fine today, back to street names at it should.
Thanks everyone.
One last not so important question.
The icon on "my computer" is now the default drive icon for the unit rather than the round red hands icon that it used to be.
I copied over the tomtom.ico from my wifes 920 but it still shows up as the default drive icon.
Any other thing it should have for it to show correctly?
dhn
PostPosted: Wed Oct 07, 2009 7:26 pm    Post subject: Reply with quote
See whether the info in this link is of assistance.
22.055 (29 May 24)
