FrequentFlyer Lifetime Member
Posted: Sat Oct 03, 2009 6:48 pm Post subject: EGNOS and SatMap |
Anything we should be aware of with this one ? 2 Mtrs as apposed to 20 Mtrs is a heck of a difference......(meanwhile I shall still continue to carry a good old paper map.) |
Bosun Frequent Visitor
Joined: May 02, 2005 Posts: 473 Location: Wakefield,West Riding of Yorkshire
Posted: Sat Oct 03, 2009 7:53 pm Post subject: |
F-F,
Yes I saw that EGNOS is now working and wondered about it regarding Satmap.
I seem to remember though when Garmin first brought out the 60CSx to replace the 60CS they had a problem with picking up WAAS and seemed reluctant to bother fixing it as they said the Sirf Star chip they were using at the time was so sensitive it didn't really need WAAS.
I think the Satmap uses this chip so perhaps that also doesn't really need EGNOS.
I shall be visiting the Cycle Show at Earls Court next week and Satmap are there,I will enquire about it.
Ian |
lucevans Frequent Visitor
![](modules/Forums/images/avatars/3593247754774ca51599f4.gif)
Joined: Mar 21, 2007 Posts: 261 Location: Cambridgeshire, UK
Posted: Sat Oct 03, 2009 10:04 pm Post subject: |
I'm sure Satmap will be looking into this now that EGNOS is finally (as of 1st Oct) fully-functional ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
nonoftheabove Regular Visitor
Posted: Sun Oct 04, 2009 10:46 am Post subject: |
Bosun while you are at the cycle show maybe have a gander at the Memory Map device and report back
is it worked via touch screen etc.
looking at the images from Web site there seem to be a
minimalistic number of function buttons shown
also any improvement for Satmap devices would be useful to know about |
Posted: Sun Oct 04, 2009 7:22 pm Post subject: |
nonoftheabove wrote: | Bosun while you are at the cycle show maybe have a gander at the Memory Map device and report back
Yes I will have a sniff around,Mrs.Bosun permitting!!
Ian |
johno99 Regular Visitor
Posted: Mon Oct 05, 2009 11:34 am Post subject: |
This is on Satmaps site, (FAQs) think I need someone to expalin in laymans terms!
Is the Active 10 WAAS/EGNOS enabled – my Garmin is?
WAAS & EGNOS are ground based systems designed to supplement the GPS signal. These systems were developed at a time when the GPS service was providing poor accuracy. Modern GPS chipsets offer a much higher degree of accuracy now: we in fact are using the SiRF Star III which is widely considered to be the most advanced GPS chipsets available. The accuracy this offers renders the need for a ground based augmentation system largely irrelevant.
In fact, it is for this very reason that neither WAAS nor EGNOS are likely to be rolled out anywhere other than the limited areas of coverage they currently provide. The EU is, instead, diverting financial resources into the establishment of the Galileo Satellite navigation system, thereby signalling the de facto end of EGNOS specifically. And, as you are probably aware, WAAS applied only in the USA, and even then in only limited areas, and this too is not being extended. |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Mon Oct 05, 2009 11:47 am Post subject: |
Hmm, they have a point but as you know they are wholly wrong about EGNOS's future.
It's being rolled out to support aviation users, it is not and was never intended for hikers and other outdoor usage.
I'll ask Satmap what plans they have for EGNOS but the service is not designed for reception in the type of conditions prevalent in mountains etc. _________________ Darren Griffin |
Posted: Mon Oct 05, 2009 1:16 pm Post subject: |
EGNOS went live in Europe (including the UK) on 1st Oct 2009. See http://europa.eu/rapid/pressReleasesAction.do?reference=IP/09/1399 for details.
It really is there, and it improves the reported accuracy of handheld GPS units when the EGNOS signal is visible- I can attest to that from personal experience over the last few days. However, I agree completely with Darren; According to Wikipedia, the EGNOS system consists of 3 satellites - so when in a steep-sided valley, the chances of seeing one of those satellites is not great.
No line-of-sight = No EGNOS augmentation of the standard GPS position.
With good reception, even standard positioning on the A10 can give me 5m accuracy; EGNOS might give 2-3m, so the difference when looking at an OS map is pretty minimal really, but if it's available why not make use of it? |
Posted: Mon Oct 05, 2009 5:10 pm Post subject: |
How do you tell it's EGNOS and not the regular sat's you're picking up ? |
Posted: Mon Oct 05, 2009 5:14 pm Post subject: |
EGNOS SV's have a PRN ID Codes 120,126 & 131 _________________ Darren Griffin |
Posted: Mon Oct 05, 2009 7:22 pm Post subject: |
FrequentFlyer wrote: | How do you tell it's EGNOS and not the regular sat's you're picking up ? |
Edit: see Darren's advice above - When I had EGNOS enabled, one of the satellites had a PRN in his list. |
