arturus Occasional Visitor
Joined: 12/05/2003 22:33:26 Posts: 35 Location: Surrey.United Kingdom
Posted: Tue Jul 06, 2004 12:25 pm Post subject: POI for JD Wetherspoon pub chain |
Hi all
Does anyone have a POI for JD Wetherspoon pub chain or a listing of their pubs with locations that I may be able to use?
Arturus |
alix776 Pocket GPS Moderator
Posted: Tue Jul 06, 2004 1:42 pm Post subject: |
if your run checkpoint 3.02 then you sync check point with poihandlers site there a poi for jds there _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Tue Jul 06, 2004 2:26 pm Post subject: |
Thanks Alix for that qick info. Will give it a go.
Arturus |
Posted: Tue Jul 06, 2004 2:52 pm Post subject: |
Hi Alix
I went to POIhandler but could not find the JD Wetherspoon overlay.I checked through the list of UK overlays and could not find it.
Arturus |
Posted: Sat Jul 10, 2004 8:12 am Post subject: |
it is there if you go to to poi handler via poi fdit the you should find it _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jul 10, 2004 9:38 am Post subject: |
Hi Alix
Have been back to POI Handler----but still can't find it---I've got to be thick or blind.
Anyway I have emailed them and asked them to confirm that this POI exhists on their site. Will post with result--if it comes through.
Arturus |
Posted: Sat Jul 10, 2004 10:54 am Post subject: |
when your in poi edit change to dowload site from pocketgps to poi hanlder that should bringit up _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jul 10, 2004 2:03 pm Post subject: |
Thats what I have been doing---but no JD Wetherspoon found
Arturus |
Posted: Sat Jul 10, 2004 2:39 pm Post subject: |
its there ive seen itand had it on my system
i know what i did i used the sync system on checkpoint as im running 3.02 if you do that you should get it and just delete what you dont want via poi edit _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Jul 11, 2004 3:35 pm Post subject: |
Have just received a reply back from PoiHandler that they do NOT have a JD Wetherspoon POI--this from Marcel Timmermans.
I was sure that somewhere I had seen a POI for JD's--I must be dreaming.
He also says that if I can get the addresses he can make a POI.
Arturus. |
mrklaw Regular Visitor
Posted: Sun Jul 11, 2004 5:30 pm Post subject: |
I thought I saw one after registering at POIplace and digging down in the synch options in checkpoint. Just after I'd seen this thread in fact.
yep, there under hotels and restaurants, in the restaurant section. |
Posted: Mon Jul 12, 2004 12:29 am Post subject: |
MrKlaw--------Thanks a lot. Spot on. I've been looking on PoiHandler and had completely forgotten about PoiPlace. I've found it. I was beginning to think I was going round the bend
Arturus. |
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Wed Mar 15, 2006 10:06 pm Post subject: |
They have their own on their web site (here), it's for TomTom but you should be able to use POIConverter to convert it to whatever format you need. _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
