Pocket GPS World :: View topic - Transfering routs from satmap rout planner to active 10
nick789uk
PostPosted: Fri Sep 25, 2009 9:05 pm    Post subject: Transfering routs from satmap rout planner to active 10 Reply with quote
Hi everyone
Sorry if this has been covered before but could not find anything on this in the forum. I recently planned a couple of routs in the rout planner saved them and then tried to use the funtion to import strait to the active 10 but nothing happened, I had to go back into the sync programe and import them through that to the device, does the function to import straight from rout planner work or not any help on this would be greatful.
LostMike
PostPosted: Sat Sep 26, 2009 1:37 pm    Post subject: Reply with quote
Nick I don't think the route planner was ever intended to export directly to the A10 it says it downloads a .gpx file for export to the A10. It does not download to the A10 or export to the A10. So what you did in downloading the .gpx and then using Satsync is what is intended. I believe.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
jonesbach
Not something I use but I think I follow you. I take it you are going into Satsync and trying to use the 'Route Planner' button to import straight into the Satmap.
I can see your point, I had thought it was there for download, but it looks as if it will just open the window for you to manually download. Perhaps others have more information.
nick789uk
PostPosted: Sat Sep 26, 2009 8:38 pm    Post subject: Reply with quote
Ok thanks for that it just seems strange for it to say download to the A10 when it soes not maybe it will in a future update.
22.105 (30 Oct 24)
