Pocket GPS World :: View topic - update 3.03
update 3.03
lee123
PostPosted: Mon Jul 05, 2004 5:56 pm    Post subject: update 3.03 Reply with quote
hi all i have just updated my tomtom from 3.01 to 3.03 and now when i click on it it say i have to install a map and re-activate it,as no map is found any one had this prob, also any way round this as it worked fine befor.
lee123
PostPosted: Mon Jul 05, 2004 6:33 pm    Post subject: Reply with quote
If you still have the map on storage card see if you can browse to it via File Explorer on the PPC. if you can't see it that way try ejecting and re-inserting the card.
lee123
PostPosted: Mon Jul 05, 2004 6:57 pm    Post subject: Reply with quote
thanks map was gone just reinstalled the map and it is now gone again but only after i activated it again
lee
PostPosted: Mon Jul 05, 2004 7:05 pm    Post subject: Reply with quote
The map has dissappeared again? Sounds more like a problem with your storage card. Check it out with Storage Tools.
lee123
PostPosted: Mon Jul 05, 2004 8:52 pm    Post subject: Reply with quote
thanks now scaning storage card on my ipaq, just say repairing for the last 10 mins this dont seem right. may be i will have to reformat it
lee
PostPosted: Mon Jul 05, 2004 8:54 pm    Post subject: Reply with quote
It can take a long time, give it up to an hour, failing that format and re-install the map. If you format go for FAT32.
lee123
PostPosted: Mon Jul 05, 2004 10:18 pm    Post subject: Reply with quote
ok did all that reinstalled and worked fine then i loaded update 3.03 and it now say "no maps found, please install and activate an original tomtom nav 3 map first"
any help anyone
lee
tom9851
PostPosted: Tue Jul 06, 2004 6:57 am    Post subject: Reply with quote
Yes, I had same problem upgrading from 3.01 to 3.03 - in fact happened twice in a row. Got so arsed off with the whole thing that I reformatted the SD card and did a hard reset to the Ipaq and did a complete re-installation of TTN3 3.01 then 3.03 - now works perfectly. A drastic step to have to take but I could think of no other solution.
Tom
___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338
oddsock
PostPosted: Tue Jul 06, 2004 11:18 am    Post subject: Reply with quote
Would you recommend fat32 for a 256 Dane-Elec CF(Toshiba) card.??.I used mine straight fron the packet and storage tools tells me it is fat 16
thanks
PostPosted: Tue Jul 06, 2004 1:03 pm    Post subject: Reply with quote
Unless you are experiencing problems then there is no problem leaving it as FAT16. If you do have to format it at any stage then I recommend FAT32.
If it ain't broke, don't fix it Thumbs Up
oddsock
PostPosted: Tue Jul 06, 2004 1:15 pm    Post subject: Reply with quote
Thanks, I will take your advice!.. If at some stage in the future I have to format ,can I back up the whole of the CF card onto myPC with Sprite premium ..do the format and then resore or is there a better way Question
PostPosted: Tue Jul 06, 2004 1:21 pm    Post subject: Reply with quote
The easiest way would be to simply copy the contents of your CF card to a folder on the PC, unless you have a card reader though this would be a slow process for a full 128 or 256Mb card via ActiveSync.
oddsock
PostPosted: Tue Jul 06, 2004 2:30 pm    Post subject: Reply with quote
I will try that way if the need arises!
thanks
dave
22.064 (26 Jun 24)
