Pocket GPS World :: View topic - Turning off the ONE and 720
G4GVB
PostPosted: Fri Sep 18, 2009 10:36 am    Post subject: Turning off the ONE and 720 Reply with quote
Is there any way you can do a full turn off, so the batteries don't go flat after a couple of weeks non use?
GO 750 LIVE v9.430 - v8.753612 EU map
XL 350 MT v9.151 - v8.75366 US Map
PostPosted: Fri Sep 18, 2009 10:57 am    Post subject: Reply with quote
If the units got a reset switch in the base (the 720 certainly has) the One will depend upon which model you have, simply use a paperclip to press the reset and put the device away, you won't lose any settings or data doing this - If the device has no reset switch and relys upon the on/ off switch acting as a reset switch then there is nothing you can do - Mike
G4GVB
PostPosted: Fri Sep 18, 2009 11:08 am    Post subject: Reply with quote
Thanks Mike, mega fast reply as usual. I'II give it a try.
22.062 (12 Jun 24)
