Pocket GPS World :: View topic - Geocoded PostCode Database Leaked Online
Goto page 1, 2, 3, 4  Next
PostPosted: Wed Sep 16, 2009 5:19 pm    Post subject: Geocoded PostCode Database Leaked Online Reply with quote
pocketgpsworld.comA database containing 1.8 million Post Codes with geocoded Lat/Lon locations and grid references has been leaked by Wikileaks, the whistleblower website.
The source of the 240mb file is unclear but it does not contain any names or addresses unlike the full Royal Mail PostCode Address File (PAF).
There have been many calls for the PAF data to be made available by businesses and freedom of information campaigners. The Royal Mail charge a hefty licence fee for access to the database containing the full name and address information but even this cut down version might prove very useful to satnav manufacturers not that we're suggesting they would use data from an unknown source such as this!
Wikileaks are even offering the database, in all it's 100,000 page glory as a compressed 20mb file and have even seeded it via Torrent Sites. Given the dubious nature of the data and the unknown source this may be a step too far for the whistle blower premise of the web site?
Wazza_G
PostPosted: Wed Sep 16, 2009 6:24 pm    Post subject: Reply with quote
I downloaded a copy before it's removed, so should anyone want it...
pcaouolte
PostPosted: Wed Sep 16, 2009 6:53 pm    Post subject: Reply with quote
Downloaded it Very Happy
Now I just need to work out how to convert 1.8million locations into a POI file that I can use with a satnav. Confused
Paul
253
PostPosted: Wed Sep 16, 2009 7:52 pm    Post subject: Reply with quote
Yep, downloaded it as well.
Have no idea what I'm going to do with it though.
Probably delete it in three months time like the rest of the stuff that seems like a good idea at the time, but just clutters up the place.
navver
PostPosted: Wed Sep 16, 2009 8:32 pm    Post subject: Reply with quote
I guess you'd need to load it into Excel, then remove all the unwanted fields by deleting columns, then save it as a .TXT file.
Then load into POIEDIT then save in the format you want to use eg Tomtom OV2.
Tomtom Go520, App 8.010, Map UK&ROI 810.1870
Ray4438
PostPosted: Wed Sep 16, 2009 9:01 pm    Post subject: Reply with quote
Can u tell me what program opens it after un zipping it.
PostPosted: Wed Sep 16, 2009 9:06 pm    Post subject: Reply with quote
I don't know if the later versions of Excel can handle 1.8 million rows but previous versions could only load 65,535 Sad
It's not only the excess columns that need removing, there's also the problem of blank cells where the lat/long has not been provided. Presumably due to that particular Postcode not being used.
TT Via 135 App 12.075: Europe Map v1140
Ray4438
PostPosted: Wed Sep 16, 2009 9:33 pm    Post subject: Reply with quote
And how to open it?
navver
PostPosted: Wed Sep 16, 2009 11:03 pm    Post subject: Reply with quote
I managed to open it with wordpad. Not sure if that will add format characters.
I had a postcode POI for my Mavman 635. That was split into many different files, broken down by area such as "Southwest" and each area was split into 2 or 3 files.
You could do the same in word pad, then load into excel, unless someone can write a utility to remove the unwanted columns.
JockTamsonsBairn
PostPosted: Thu Sep 17, 2009 12:14 am    Post subject: Reply with quote
I'm sure Dennis will be along shortly to recommend Lotus 123 Laughing
Jock
BigPerk
PostPosted: Thu Sep 17, 2009 12:35 am    Post subject: Reply with quote
navver - interested in your comment about txt files and POIEdit. Unfortunately I'm not very clued up on POIEdit, so I (thought I) had a problem when I was trying to use a txt file output from OpenOffice because POIEdit didn't show txt as an input file type option, so I assumed I couldn't use it. (I wanted to convert to asc).
Can you enlighten me please Sad ?
(Navigon 70 Live, Nuvi 360)
PostPosted: Thu Sep 17, 2009 6:40 am    Post subject: Reply with quote
BigPerk wrote:
..... (I wanted to convert to asc).
Just change the 3 letter extension from .txt to .asc
253
PostPosted: Thu Sep 17, 2009 7:24 am    Post subject: Reply with quote
I'm on a Mac, opened the file using Text Edit no problem.
Have Microsoft Excel (Office 2008), but no way could I copy across, not even when I chopped it up into what I thought were smal lumps.
Didn't have a lot of time last night, but will spend a bit longer tonight.
PostPosted: Thu Sep 17, 2009 8:36 am    Post subject: Reply with quote
I might run it through some software I have on the PC later and break it down into each County which should make the size more managable, I can also filter out those unused/ blank codes at the same time - Mike
PostPosted: Thu Sep 17, 2009 8:53 am    Post subject: Reply with quote
yay! you've finally found something of use to use that program on!!!
Page 1 of 4
23.012 (08 Jan 25)
