Brianpowell123 Occasional Visitor
Posted: Sun Sep 13, 2009 1:26 pm Post subject: creating a folder on the memory stick for Nissan Connect |
When I attempt to create the folder x:\my pois\mypoiwarnings as soon as I enter the : and the \ it will not accept the characters. I've tried 2 different memory sticks with the same effect |
Andy_P Pocket GPS Moderator
Posted: Sun Sep 13, 2009 9:39 pm Post subject: |
Are you trying to follow this instruction?
Quote: | 4. Create a folder on the USB mass storage device (where x = USB mass storage device drive letter) as follows:
x:\my POIs\myPOIWarnings (Note the SPACE between 'my' and 'POIs' in the first folder!) |
(From the description HERE)
If so, all it means is to make a folder on the memory stick called "my POIs" and then to make another folder inside that called "myPOIWarnings"
All the colons and slashes are shorthand for that, taken from the old DOS operating system, where drives and folder paths WERE described specifically lie that. |
Posted: Mon Sep 14, 2009 3:52 pm Post subject: |
Thanks for the help Andy, I created the folders as you said and have transfered the file as downloaded but it is not being accepted by the connect, I've been 3 days on this and am running out of ideas
Regards, Brian
Is this file 134kb. I'm wondering if I'm getting all of it. If I try to open it the computer goes berserk flashing on and off so I send the file to a location and click on select all to remove the zip files. I then send it to mypoiwarnings folder and transfer the poiwarnings folder into the pois folder.Have I gone wrong somewhere??????????
I've also scanned the file for viruses. |
Posted: Mon Sep 14, 2009 8:01 pm Post subject: |
Sorry, I'm afraid I can't be any more help... I understood the folder instruction when I read it, but I haven't a clue about anything specific to the actual Nissan Connect... never even seen one. |
Darren Frequent Visitor
Posted: Mon Sep 14, 2009 8:13 pm Post subject: |
Brianpowell123 wrote: | Thanks for the help Andy, I created the folders as you said and have transfered the file as downloaded but it is not being accepted by the connect, I've been 3 days on this and am running out of ideas |
I did reply to your support ticket on this issue, did you get it?
What files do you now have in your 'myPOIWarnings' folder? _________________ Darren Griffin |
Posted: Wed Sep 16, 2009 12:42 pm Post subject: nissan connect download |
hello Darren
The folder named ''myPOIWARNINGS'' is advised as a compressed (zipped) folder containing file pgsw-speed-cams-xxxx
I assume that the '' and '' symbols have no significance to the name of the folder |
Posted: Wed Sep 16, 2009 12:52 pm Post subject: |
I have edited out part the file name you wrote above as it is part of our anti-piracy system.
What 'and' symbols are you referring to? I'm not quite sure what you have here but 'myPOIWarnings' should be a normal folder and it should contain the 'contents' of the zipped database you downloaded from us and not the .zip file itself.
i.e. you download our database which is a compressed (.zip) file and then you extract (uncompress) the contents. It is these resulting files that should be copied to the myPOIWarnings (also note the correct case sensitivity of the folder name).
This is all laid out in the installation guide. _________________ Darren Griffin |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Wed Sep 16, 2009 2:14 pm Post subject: |
Brianpowell123 wrote: | hello Darren
Darren wrote: | What 'and' symbols are you referring to? | Darren, I THINK Brianpowell123's post meant
I assume that the Open Double Quotes and Close Double Quotes symbols have no significance to the name of the folder |
_________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Wed Sep 16, 2009 2:17 pm Post subject: |
Ah yes, penny drops, sorry! The quotes are not required in the actual folder name. _________________ Darren Griffin |
Posted: Thu Sep 17, 2009 10:55 am Post subject: |
Hello again Darren, I think my problem was not realising that the folder titles are case sensitive and had downloaded the file and decompressed it successfully, however, on renaming the folders I neglected to enter the space between the my and POIs. This resulted in a part download as the proceedure did not complete as listed in the 'Connect' booklet.I then pressed the 'Remove my POIs' expecting to start from scratch but nothing happened. I then pressed 'Factory settings' thinking this would enable me to re enter the memory stick. I appear to be back to square one as there is no response from the 'Connect' |
Posted: Thu Sep 17, 2009 11:25 am Post subject: |
Ok, if you have now got the correct folder structure you should be able to browse to your memory stick and see the first folder:
my POIs with space!
Clicking on that will show you the next folder:
myPOIWarnings
Assuming we're Ok so far, within that folder you should now see a number of files, exclusing any help and licence files which you need to have the following:
pocketgps_uk_pmobile.csv
pocketgps_uk_sc.csv
Do you have them? _________________ Darren Griffin |
Posted: Thu Sep 17, 2009 1:02 pm Post subject: |
I have six files in all, including the ones you've stated.
Last edited by Brianpowell123 on Thu Sep 17, 2009 1:05 pm; edited 1 time in total |
Posted: Thu Sep 17, 2009 1:04 pm Post subject: |
But do you have the folders as I listed and the files I named above? _________________ Darren Griffin |
Posted: Thu Sep 17, 2009 1:09 pm Post subject: |
yes I have the folders correctly named, the six files I put into the 'Warnings' folder and then put the 'Warnings folder' into the my POIs folder. |
Posted: Thu Sep 17, 2009 5:43 pm Post subject: |
Can you post a screen dump from Windows Explorer? A picture's worth a thousand words?
From memory there is also a utility, which I've searched for and cant find (x-dir, z-dir??), that allows you to get a fuller listing of a directory structure. Maybe one of the team can remember? _________________ Jock
