den9112 Occasional Visitor
Posted: Sun Sep 13, 2009 9:19 am Post subject: How to upload /overlay gpx route on to memory map |
Hi, i did a route yesterday that i converted to a gpx from memory map to the active 10 , could someone please tell me how i can upload the route from the satmap so i can see on memory map were i walked. Thanks |
Posted: Sun Sep 13, 2009 9:43 am Post subject: |
Use Sat Sync on the PC to copy/ convert the track to gpx format then it will be able to import in to the Memory Map application, its basically the oposite of what you did yesterday, but in MM use Overlay/ Import and select gpx for the file type in the drop down box before pointing the browser to the gpx file on your PC - Mike |
Posted: Sun Sep 13, 2009 9:52 am Post subject: |
Thanks for that, do you happen to know when you are charging the sat map if there is any way of knowing when the battery is full .Thanks |
Posted: Sun Sep 13, 2009 11:11 am Post subject: |
For charging the device I plug it in over night prior to the day of use and use the mains charger, in the morning remember to power off the device until you get to the start of your walk, this way will ensure its fully charged and ready to go when you need it, the battery charge indicator isn't really much use to judge charge state - Mike |
