cliffg Lifetime Member
Posted: Fri Sep 11, 2009 12:18 pm Post subject: Changing Version Downloaded |
I just downloaded and installed the 'consolidated' version. However after looking further I think that the speed zoned cameras may have been the better option as it gives informaton on what your speed should be.
I cannot now seem to download this version. When I go to the download page there is "You last downloaded . . .and a button that says 'Download same format (current version)'.
Is there a way of cahnging this?
Thanks,
Cliff |
Posted: Fri Sep 11, 2009 12:20 pm Post subject: |
If you look immediately below that button you can start the select process again in the same way you did before using the drop down lists. |
Posted: Fri Sep 11, 2009 4:09 pm Post subject: |
In addition to downloading and installing the Speed Zoned database (which is the best IMHO) you should remove the consolodated by type database from your device to avoid double warnings. You can either delete the POI categories directly on the device or do it via Windows Explorer, the files you need to remove are as follows:
pocketgps_uk_mobile.ov2
pocketgps_uk_gatso.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
There is no point in removing the pocketgps_uk_redlight.ov2 file as it is the same file included with the speed zoned download - Mike |
Andy_P Pocket GPS Moderator
Posted: Fri Sep 11, 2009 6:13 pm Post subject: Re: Changing Version Downloaded |
cliffg wrote: | When I go to the download page there is "You last downloaded . . .and a button that says 'Download same format (current version)'. |
That button was added just to make it easier for people who want to download the same version every time, so they didn't have to use the drop-down boxes again and again. |
