RobertV Regular Visitor
![](modules/Forums/images/avatars/gallery/004.gif)
Joined: Jan 08, 2006 Posts: 74 Location: Newcastle Upon Tyne, UK
Posted: Tue Sep 08, 2009 10:11 pm Post subject: Side Window antenna location |
Haas anyone mounted their external antenna on a rear side window? My Scenic has a metelized windscreen so I really need to use an extenal antenna on my Nuvi 660 to get around a problem of slow response. It would be very convenient to be able to mount an external antenna on the rear side window using a suction mount. However, I am not sure whether that would be a practical location. Any help or advice would be much appreciated. _________________ Garmin NUVI 660 with 2010 maps, Navman 550, Garmin Etrex Vista, Garmin 775 |
BeatO Regular Visitor
![](modules/Forums/images/avatars/158756937443ef26bddccc7.gif)
Joined: Feb 11, 2006 Posts: 109 Location: Zurich, Switzerland
Posted: Tue Sep 08, 2009 11:14 pm Post subject: |
Hi M8
I would not recommend the antenna on the side window, as you won't have a clear view to the sky. It is very easy to install it quite well on a Scenic, see my picture walk through.
Although the original Installation Guide is for my Quest 2, the antenna is still mounted exactly as show and used with my new Nüvi 765T, again with the dashboard friction mount.
Hope this helps!
BeatO _________________ nüvi 765T Firmware 4.50 CN Europe NT 2013.30
Quest 2 Firmware 3.10 CN Europe NT 2009 |
![](modules/Forums/images/avatars/gallery/Sphere_animated2.gif)
Posted: Tue Sep 08, 2009 11:20 pm Post subject: |
Does your windscreen have a dotted area behind the rear view mirror? If so this is normally untreated and i used to run my antenna around the windscreen and stuck the antenna on top of the rear view mirror with double sided tape. Worked for my i3. |
Posted: Fri Sep 11, 2009 12:21 am Post subject: |
Thanks for the responses. I do have the non-metalized area around the rear view mirror so I am opting to install the antenna there and route the wire around the windscreen down to the Nuvi. I happen to have my old Talex metal gooseneck mount so If necessary I can attach the antenna to that. _________________ Garmin NUVI 660 with 2010 maps, Navman 550, Garmin Etrex Vista, Garmin 775 |
