johncrampton Occasional Visitor
Posted: Fri Sep 04, 2009 11:59 pm Post subject: Safety cameras not working |
Hello
I've download, installed and activated PocketGPS safety cameras but I've just driven from Brighton to London and back and they don't seem to work. I went through each catagory with manage POI's as instructed. Please help.
John |
BigPerk Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_016.gif)
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Sat Sep 05, 2009 12:07 am Post subject: |
Hi johncrampton,
I think more info is needed! What satnav? How did you download? Any error messages? What so you mean by 'manage POIs as instructed'? Other questions may arise once we know a little more.
THEY DO WORK HONEST ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ David
(Navigon 70 Live, Nuvi 360) |
Posted: Sat Sep 05, 2009 1:13 am Post subject: cameras don't work |
Hello
thanks for the prompt reply. Sorry forget to mention which satnav.
I Have a Tom Tom Go 730. After installing I went to Manage POI's and then Warn when near POI. I pressed on each camera type, pressed 400 yards, chose each sound, unticked Warn only is POI is on route.
John |
AliOnHols Pocket GPS Verifier
![](modules/Forums/images/avatars/21465796014c9af163c058d.jpg)
Posted: Sat Sep 05, 2009 8:00 am Post subject: Re: cameras don't work |
johncrampton wrote: | ...... I pressed on each camera type, pressed 400 yards, chose each sound, unticked Warn only is POI is on route... |
A few things -
a) When you say that you get no warnings, is that visual, audible or both?
b) In the TT Folder where your map is stored you have three files for every safety camera catagory with the exact same wording apart from the file extensions, i.e.-- *.ov2, *.bmp & *.ogg. You may also have an optional 4th file called *_X2.bmp
c) when you say you chose each sound, what sound did you choose? To get the Spoken_Warning.ogg files to work from this site, you need to select "sound effect". However, when you select this you can't hear a confirmation sound, just carry on regardless.
EDIT - ignore the following question d). I have just re-read your original post.
d) how did you test? By demo route? or by driving past known camera position? Have you checked that the camera is on the Camera Submissions MAp? - You may be testing against a camera that has not yet been submitted! _________________ Garmin Nuvi 2599
SatMap Active 10 & 20.
Posted: Sat Sep 05, 2009 8:05 am Post subject: |
When you get to the screen that says Is this the sound you want to use" the device doesn't play a sound, make sure you select YES to carry on with the process, pressing No will crash the device - Mike |
Posted: Sat Sep 05, 2009 8:52 pm Post subject: can't get safety camaras to work |
Hello alionhols
the sounds I chose were the usual options ... bell, cow, trumpet etc. I don't get visuals or audio. Nothing at all.
I looked in the map folder and all the files you mention are there (apart from last one). I tried it out on round trip from Brighton to London.
John |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Sat Sep 05, 2009 9:50 pm Post subject: |
Which database download did you use? Speed-zoned, or Consolidated by Type?
How many different camera types can you see when you set the Warnings?
Have you ensured that you have selected Show POI on Map for each camera type? _________________ Garmin DriveSmart 50 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Sat Sep 05, 2009 10:03 pm Post subject: |
We might have missed an obvious one....
Do you tick the "warn only when on route" option when you set up each camera type?
If you did, and then just drove, without getting the TomTom to calculate the route for you, then the alerts will not happen. |
Posted: Sun Sep 06, 2009 12:02 am Post subject: |
Hello all
thanks for your time in solving this.
I used speed zoned. I saw loads of different speed cameras when I set the warnings. Yes I have selected Show POI on map.
John |
Posted: Sun Sep 06, 2009 12:34 am Post subject: |
And my last question? |
Posted: Sun Sep 06, 2009 9:13 am Post subject: |
johncrampton wrote: | Hello all
John |
How many is "Loads"? I'm just wondering if you have either not copied all the files across, or overstepped your POI category limit (should be around 169 in total), which means that some of the files aren't showing.
Can you select one of the cameras that you passed which should have been showing, and confirm that the relevant category is actually presnt on your device? (e.g if it was a 40mph Gatso, is the 40mph Gatso category present?).
(... and Andy's question is still very relevant - did you have a route set when you were on your journey?) _________________ Garmin DriveSmart 50 LMT-D |
Posted: Sun Sep 06, 2009 9:56 am Post subject: |
Hi Andy_P
Yes I definately had chosen a route. I've driven quite a few long journeys since installing but absolutely nothing comes up. No audio, no alerts. When I first installed the cameras the only alerts I got were the Tom Tom alerts. So uninstalled the Tom Tom alerts with Home.
I will check out Daggers query ASAP. I only have the standard Tom Tom Go 730 POI's on my satnav, so would installing PocketGPS safety camera take me over my POI's limit?
Thankyou all for your time
John |
Darren Frequent Visitor
Posted: Sun Sep 06, 2009 10:28 am Post subject: |
Think we need to go back to the beginning here. If you have not installed any other POIs then the POI limit is not the issue here.
Can you create an A to B trial route that goes past a known camera and demo it? _________________ Darren Griffin |
Posted: Sun Sep 06, 2009 11:11 am Post subject: cant use safety camaras |
Hello Darren
I've just done a "Prepare Route" and watched the demo. The known safety cameras didn't appear.
Perhaps I should just uninstall the pocketgps cameras and re-install again?
What's the best way to uninstall?
John |
Posted: Sun Sep 06, 2009 11:16 am Post subject: |
Ok, not even a visual indication?
Can you tell me what map you use (do you have more than one map installed).
Also if you browse Manage POIs, Warn When Near. Do you see any PocketGPSxxx entries and if you do, do they have a loudspeaker icon next to them (signifies a warning has been configured). _________________ Darren Griffin |
