Pocket GPS World :: View topic - Best batteries for Garmin Street Pilot i3
Grendel1500
PostPosted: Fri Sep 04, 2009 11:59 am    Post subject: Best batteries for Garmin Street Pilot i3 Reply with quote
I used to use rechargeable 2800mAh but they never seemed to last on a long journey?
So what is the best to use?
PaulB2005
PostPosted: Fri Sep 04, 2009 12:02 pm    Post subject: Reply with quote
Either higher powered ones, or try some new ones. Rechargables will loose lifetime as they get older.
Grendel1500
PostPosted: Fri Sep 04, 2009 12:07 pm    Post subject: Reply with quote
Must admit I did tend to charge them every time I was going to use them. So I may have killed them by over charging perhaps?
Would using a normal battery make any difference or would it be too lower power?
Pocketgps
PostPosted: Fri Sep 04, 2009 12:39 pm    Post subject: Reply with quote
I’ve tried rechargeable batteries with my i3. Mine are 2500mAH, but as you say they don't last that long, always needed several sets for one long trip (say 4-5 hours). Standard Alkaline batteries do seem to last longer (say 3-4 hours for one set), but the cost rules them out. My i3 still works okay with the USB car charger, so just stick to that now if I ever use it Laughing
Grendel1500
PostPosted: Fri Sep 04, 2009 1:05 pm    Post subject: Reply with quote
I use the car charger kit when I’m in the car but was planning to mount it on my motorbike so needs to be battery unfortunately. Sad
PaulB2005
PostPosted: Fri Sep 04, 2009 1:08 pm    Post subject: Reply with quote
I believe there is a power kit for motorbikes somewhere. However i used to be able to do a 5.5 hour motorway journey on one pair of 2700 mAh batteries at first. Later i used to have to change halfway. At the end they didn't last 5 minutes. This was with almost daily use around London with the occassional long haul...
PostPosted: Fri Sep 04, 2009 7:08 pm    Post subject: Reply with quote
Try a set of Energiser Lithium cells in the device, these are quite costly but they last considerably longer than anything else currently available, make sure it says "Lithium" on the packet though as there are oter Energiser cells that look very similar and they are cheaper but no where near as good - Mike
