Pocket GPS World :: View topic - Amigo Ultra Skin 1.0.14
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
linknet
PostPosted: Sun Aug 09, 2009 2:06 pm    Post subject: Reply with quote
linknet wrote:
slide2unlock wrote:
You need french translator, not russian Wink
Original topic is here http://www.mioskins.org/viewtopic.php?f=1&t=17294
Ok, I'll have a look at it.
linknet
I'm afraid that there's no way of creating a skin for this without having an iPhone to test it on, and I wouldn't dream of paying Apples ridiculously inflated prices to own one, so it's a non-starter.
linknet
masteryodha
PostPosted: Sun Aug 30, 2009 5:28 pm    Post subject: problem with speed limit. Reply with quote
Hi, I installed the ultra skin last week and today, I found out that the speed limit in not correct.
I'll try to explain it clearly Razz
On the highway, it says that the speed limit is 161 Shocked . I wish it would be that, but it's really 100 Km. It seems that the gps thinks that the spped limit is 100Mph and tries to converts it in Km... which is 161.
My settings are in Km by the way.
So the GPS says that I'm going at 100Km and that the speed limit is 161. If I sets my settings in Mph, the gps than change to say that my current speed is 66 and the limit is 100 (Mph).
I read some thread in the forum and didn't find anything. Maybe I missed something in the sys.txt file. Or maybe it's not even a problem with the skin but with the map itself.
Could someone please help me out.
I'm using the latest Amigo version with the 2009 maps.
linknet
PostPosted: Sun Aug 30, 2009 5:44 pm    Post subject: Re: problem with speed limit. Reply with quote
The latest version that I have tested it with is iGO Amigo Version 8.4.2.85182 dated April 8th 2009 so if you are using a later version than that then you might get unexpected results.
Which actual country map are you using ? The speed limits are obtained from the map and have nothing to do with the GPS.
Regards
linknet
masteryodha
PostPosted: Sun Aug 30, 2009 10:26 pm    Post subject: Re: problem with speed limit. Reply with quote
Thanks for the quick reply.
I'm actually using AMIGO 8.4.2.95590 (Jun 23 2009) with Canada 2009.02 (TeleAtlas 090410) map.
I'll try to get the April 8th version to try it on. I will test it tomorrow.
Thank you
linknet
PostPosted: Sun Aug 30, 2009 11:25 pm    Post subject: Re: problem with speed limit. Reply with quote
Thank you
I've tested with that map for Canada and it appears to be a problem with the iGO Amigo software not recognising that the speed limits in Canada are already in km/h and then performing an unneccessary conversion by mutiplying by 1.61 Rolling Eyes
It seems that iGO8 also has this problem:
https://airis.naviextras.com/shop/mvnforum/viewthread?thread=1853
Try posting in the above forum for Amigo and see if you get any response from Nav'n'Go.
Regards
linknet
masteryodha
PostPosted: Sun Aug 30, 2009 11:33 pm    Post subject: thank you. Reply with quote
thanks. I'll post and get back if anything comes up.
thank you again for the quick answer
masteryodha
PostPosted: Tue Sep 01, 2009 4:03 am    Post subject: it's fixed.... Reply with quote
It's supposedly fixed with a firmware update of the device. But since I run it on my mio C520, I cannot update the firmware for this.
My only possibility is to get the speed limit to warn me at 70% of the actual speed limit. It will be close enough to what it should really is.
thanks anyway for your help.
linknet
PostPosted: Tue Sep 01, 2009 7:56 am    Post subject: Re: it's fixed.... Reply with quote
Updating the firmware won't fix it, it's a bug in the Amigo executable file. It happens on my HP iPAQ 214 so it's not just your device.
Warning at 70% of the indicated speed limit is a good idea and will actually warn you when you are 12.7% over the true speed limit. It would probably be best to hide the onscreen speed limit as well, just leaving the actual speed indication on screen.
Regards
linknet
mayerm
PostPosted: Wed Sep 23, 2009 8:17 am    Post subject: Re: Amigo Ultra Skin 1.0.13 Reply with quote
linknet wrote:
iGO Amigo Ultra Skin 1.0.13
The Amigo Ultra Skin adds essential extra functions to iGO Amigo to improve route planning and navigation whilst still retaining the original simple and easy to use interface.
Website ► iGO Amigo Ultra Skin
Fully compatible with the following versions:
iGO Amigo Version 8.4.2.81333 dated March 12th 2009
linknet
I have Navigon N560 with IGO Amigo 8.4.2.95590 , when i istalled Amigo Ultra Skin v.1.0.13, TMC icon to take away.
primitive_man
PostPosted: Wed Sep 23, 2009 4:21 pm    Post subject: Coordinate Search? Reply with quote
Is it possible to add a Coordinate Search to the skin?
I believe that the DJ Amigo skin has this but I've a big preference for your work.
I'm using your latest version at the moment... which is a vast improvement on my original one.
Additionally... a GPS signal status page and compass would be nice ;)
Have a nice day!
Sorry... just noticed you'd already answered this.
igal27
PostPosted: Sat Sep 26, 2009 9:36 pm    Post subject: Keyboard selection Reply with quote
thanks for your amigo skin linknet, it really is a great improvement over the standard skin, while keeping amigo "simple". i used to use mainly igo8.3 until amigo came out, and at first thought i wouldn't switch because amigo didn't have enough features, but in the end i realized i didn't really need most of the extra features in igo8 that weren't available in amigo... at first there were a few that i really missed though, which kept me on igo8 for a while, until your skin came out and covered just about everything that i found missing, so now i'm mainly using amigo with your skin. i do still miss the compass, but can live without it (i read your previous post about this and understand your reasoning). there is one other thing i really miss from igo8 though: the possibility to switch between keyboards when you're in keyboard input mode. igo8 has a button that allows you to toggle between the available keyboards, so if you need characters from another keyboard while you're typing, it's a simple matter of pressing a button to toggle to the respective keyboard. in amigo, you have to exit from wherever you are, get back to the main screen, go into more - settings - regional - keyboard, change the keyboard, and then make your way back to where you were in the first place... this happens to me a lot, as i'm using the israel map but modified the language file so that it would show me the menus etc in english, but the street names on the map in hebrew - and i sometimes need to enter addresses in english and sometimes in hebrew...
in any case, if this is not too complicated to do, it would definitely be much appreciated. if not, that's of course understandable and i'll continue using amigo with your skin despite this drawback (at least for me it's a drawback; i realize it is probably irrelevant to many...)
thanks, and keep up the good work Smile
Jards88
PostPosted: Sun Oct 04, 2009 9:59 am    Post subject: Reply with quote
Hi Linknet,
I am using the latest version of your skin on a device with 480x272 resolution. It all appears to work ok except that when I go to Settings/Regional/Voice Language, I can change the voice ok but there is no back button to get back out unlike the standard skin. So once you are in there the only way out is a reset.
Cheers, Ian
DeepBlue22
PostPosted: Sun Oct 18, 2009 3:28 am    Post subject: Reply with quote
Hey linknet,
I do miss an "Advanced Road Blocking Facility". When do you expect to implement that feature? Or perhaps "Simple Road Blocking"... Very Happy
Greetz
DeepBlue22
Back 2 the 90s!
Jimbo09
PostPosted: Sat Oct 24, 2009 3:30 pm    Post subject: hello... Reply with quote
Linknet,
for iPhone does it work....your amigo skin?
i instaled on my iphone and it says user interface resolution [320x460] is not supported!
Thank's!
Fedcup
PostPosted: Sun Nov 15, 2009 10:36 am    Post subject: Re: hello... Reply with quote
Jimbo09 wrote:
Linknet,
Thank's!
Hi Linknet.
Is it possible to convert it to a resolution of 320*460?
Or is that not possible?
Thx
Page 6 of 9
22.055 (29 May 24)
