Pocket GPS World :: View topic - Unable to download camera database onto my TOM TOM Go 510
sparky123456
PostPosted: Sun Aug 30, 2009 12:56 pm    Post subject: Unable to download camera database onto my TOM TOM Go 510 Reply with quote
Dont know if anyone esle has this problem.
No matter what I cannot download the camera datbase onto my tom tom 510.When I download from pocket gps the files I get are jpg,s & ov2 files .when i try to open the ov2 ones they wont do it & come up with unable to recognise file search web.
I looked at the guide to install but the files just come through differently for some reason.
Driving me nuts as I have padi for subs I cant use!
Mad
PostPosted: Sun Aug 30, 2009 1:14 pm    Post subject: Reply with quote
You shouldn't be trying to open the .ov2 files. The guide tells you to COPY them to the device not open them?
Calomax
PostPosted: Sun Aug 30, 2009 4:46 pm    Post subject: Re: Unable to download camera database onto my TOM TOM Go 51 Reply with quote
Shouldn't he be getting bmp files, not jpg?
TT Go Essential
PostPosted: Sun Aug 30, 2009 4:54 pm    Post subject: Reply with quote
Indeed but that could simply be a term the OP uses for any image file. We don't serve .JPEG's so I cannot see how he could get them?
sparky123456
PostPosted: Sun Aug 30, 2009 5:01 pm    Post subject: Tom tom 510 camera download Reply with quote
Thanks for all your replies.I did copy & paste the file into the poi,s file on my tom tom.
I acessed it via "my computer" and fopund the files with bmp,s in.
dont know if it worked, but my tom tom accepted the files with the red cross for uploading.used the folder containing Uk & IE plus major roads of WE to add the camera database.
PostPosted: Sun Aug 30, 2009 5:14 pm    Post subject: Reply with quote
Have you followed the guide to set-up and configure them? It's not just a matter of copying them. Also, do you only have a UK map?
sparky123456
PostPosted: Sun Aug 30, 2009 5:22 pm    Post subject: Tom tom 510 camera download Reply with quote
Have checked on my tom tom for the speed camera & other poi,s I have uploaded onto my tom tom.They seem to be there.
They were bmp files not jpg btw.
Will take your advice though.Thank for your help.
PostPosted: Sun Aug 30, 2009 5:28 pm    Post subject: Reply with quote
No problem, if you have any Q's we're here to help Thumbs Up
EricWB
PostPosted: Sun Aug 30, 2009 6:18 pm    Post subject: Reply with quote
When you unzip the files from GPS you will have ?????.bmp & ?????.ov2 files, as pairs where each pair has the same name for each type of camera. These should be copied and pasted into the MAP folder for the map you are using not the POI one you have mentioned.
If you want spoken warnings you also need to download and unzip your choice of voice. These become ?????.ogg files that are also copied and pasted into the same MAP folder. If you have chosen a separate warning for each type of camera they will also have simlar names but its not essential.
Then you have to follow the detailed instructions to be found in the FAQ's section upon how to configure everything to work together correctly.
Its a bit long winded first time round but once done you only have to update when required by downloading new camera files and unzip, copy paste to the MAP file and thats it. You seem to suggest you maybe trying to add them to your POI's folder but you also mention the MAP folder so this point is not clear.
I have a TT510 and it all works OK for me.
PostPosted: Sun Aug 30, 2009 6:23 pm    Post subject: Reply with quote
The OP never mentioned a POI folder, he said he'd pasted into the
folder which is correct?
JockTamsonsBairn
PostPosted: Mon Aug 31, 2009 2:14 am    Post subject: Re: Tom tom 510 camera download Reply with quote
sparky123456 wrote:
I think by file he meant folder, unless he's somehow overwritten the TT POIs file?
Jock
PostPosted: Mon Aug 31, 2009 10:49 am    Post subject: Reply with quote
Indeed and my apols for missing the POI reference, I looked but completely missed it Embarassed
