Pocket GPS World :: View topic - Garmin / Kenwood KNA-G421
tomsk2
PostPosted: Sun Aug 30, 2009 1:30 am    Post subject: Garmin / Kenwood KNA-G421 Reply with quote
I have downloaded the database via poiloader to an SD card, when I put the card into the GPS module the GPS screen freezes.
Any Ideas?
PaulB2005
PostPosted: Sun Aug 30, 2009 1:49 pm    Post subject: Reply with quote
Moved to more appropriate forum...
PaulB2005
PostPosted: Sun Aug 30, 2009 1:50 pm    Post subject: Reply with quote
Have you put the Kenwood into NAV mode?
tomsk2
PostPosted: Mon Aug 31, 2009 10:15 pm    Post subject: Reply with quote
I have tried putting the sd card in with the unit turned off and then switching on, this gives a garmin screen save with no interaction to sat nav menu at all.
If I switch the unit on and put the sd card in the nav screen operates as normal but there are no custom POI's showing and nothing on the sat nav map.
I have loaded the card via poiloader direct so if you look at the card it contains the following: garmin/poi/poi.gpi
Any Ideas?
PaulB2005
PostPosted: Tue Sep 01, 2009 7:39 am    Post subject: Reply with quote
2 more things to try.
One try just having the poi.gpi file in a folder called garmin (i.e. no poi folder. Try it with a capital G if lower case G fails.
Kenwood and Garmin haven't been consistent across the range on how to load the database to these units....
