harley-noj Regular Visitor
![](modules/Forums/images/avatars/gallery/simpsons17.jpg)
Joined: Mar 18, 2006 Posts: 86 Location: South Yorkshire
Posted: Fri Aug 21, 2009 12:04 am Post subject: Rider new map not found |
Hi All
Just finished downloading the new map using TT home onto a rider 1. Again it says no map found. 1st time I did this same result so I put a back up on it worked fine with that. Downloaded the map again same result. Whats happening?
Any help as at the moment its no maps found
Noj |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Fri Aug 21, 2009 1:28 am Post subject: |
Do you have the most recent application for your model? _________________ David |
Posted: Fri Aug 21, 2009 3:54 pm Post subject: |
Hi Just a quick update. Having had a happy 30 mins with TT support, during which time the application was removed and reload. I've still got the same problem. Its as if its the wrong map version for my rider. But support says its OK!!!
Now its get some screen shots of the contents and send off to 2nd line support
At least I can put the old map back on and use the rider whilst this gets sorted
Noj |
Posted: Sat Aug 22, 2009 12:38 am Post subject: |
All the info TT asked for has now been sent.
So I tried the following, went back to an old application and map.
It worked.
Updated application, it worked,
Using home downloaded new map, cannot see it. deleted map, then added it using home.
IT WORKS!!!!!!!
Map is now 835.2421 is this the latest map?
App 7.901
Noj |
Posted: Sat Aug 22, 2009 1:00 am Post subject: |
You have the latest map. _________________ David |
Posted: Sat Aug 22, 2009 12:09 pm Post subject: |
Thanks for the info, It was the only thing I wasn't sure about
Noj |
