crypticx Occasional Visitor
![](My Albums)
Posted: Thu Aug 20, 2009 8:18 pm Post subject: go 730 quick fix |
had this one for last 3 month but the last 5 weeks when i update with tomtom home get the mapshare ok .but no quick fix. had a problem with the maps kept coming up no maps found.had made aback up.so decided to format it.no probs .but since then no quick fix.hope somebody can help with this.thanks in advance |
Andy_P Pocket GPS Moderator
Posted: Thu Aug 20, 2009 8:45 pm Post subject: |
Try this:
1. Find the "ephem" folder on the TomTom itself and delete the contents (leaving the folder empty).
2. On your PC, go to where Home stores it's downloads (normally C:\Documents and Settings\username\My Documents\TomTom\HOME\Downloads\complete on an XP machine) and find the "ephemeris" folder. Again, delete all the contents, leaving the folder empty.
That should kick-start the GPSQuickFix downloads again, next time you connect to Home. |
![](My Albums)
Posted: Fri Aug 21, 2009 4:39 pm Post subject: |
will give it a go m8 just got home. another thing is when i connect tomtom then go to start my computer i have drie c and drive d but my tomtom is now showing up as removeable drie f .instead of romtom |
Posted: Fri Aug 21, 2009 4:55 pm Post subject: |
Don't worry about the drive not showing up as named "TomTom" and the actual letter it uses will change from time to time if you add/ remove other USB memory devices to the PC such as digital cameras etc - Mike |
![](My Albums)
Posted: Fri Aug 21, 2009 6:59 pm Post subject: |
right first of all thanks andy and mike.have deleted the content of the ephem on my comp.but cant find it on my tomtom-unless its hidden |
Posted: Fri Aug 21, 2009 7:19 pm Post subject: |
Has your device not got an "ephem" folder in the root of the device? - It should be in there - Mike |
![](My Albums)
Posted: Fri Aug 21, 2009 7:38 pm Post subject: |
alright mike dont know what you mean about root.been through every folder on my tomtom cant find ephem anywere.thanks |
![](My Albums)
Posted: Fri Aug 21, 2009 7:54 pm Post subject: |
should i just make a "ephem" folder and put it on my tomtom |
Posted: Fri Aug 21, 2009 7:55 pm Post subject: |
When you connect the device to the PC and use Windows Explorer your device appears as a seperate drive letter, when you expand/ open this by clicking it you are in the "Root" directory, its the highest level available to you before you start to drill in to the individual folders - Mike |
![](My Albums)
Posted: Fri Aug 21, 2009 8:16 pm Post subject: |
thanks mike but no "ephem" folder to be found. bit stuck now |
AndyVaughan Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_matrix_014.jpg)
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Fri Aug 21, 2009 8:17 pm Post subject: |
crypticx wrote: | should i just make a "ephem" folder and put it on my tomtom |
If you don't have the ephem folder that is why QGPSFix isn't being offered.
With your device connected to your PC just open the drive letter that is your TT with Explorer and create a folder called ephem
Now HOME should offer you the QGPSFix
TT made a mess of a Navcore release not long ago and missed out the ephem folder from the build ....... |
![](My Albums)
Posted: Fri Aug 21, 2009 8:49 pm Post subject: |
well have tried that and still no quick fix in the ephem file on my comp in ephem there are 3 files ee meta tlv packedephem erris.ee ee meta are they the ones to delete.i have dragged the on to my desktop.so the folder is now empty.just incase i have the wrong folder.i can always put them back thanks |
![](My Albums)
Posted: Sat Aug 22, 2009 1:35 pm Post subject: |
ok sorted it went to a back up and put the folder of there into tomtom and quick fix works thanks for all your help |
