Pocket GPS World :: View topic - Rider new map not found
harley-noj
PostPosted: Fri Aug 21, 2009 12:04 am    Post subject: Rider new map not found Reply with quote
Hi All
Just finished downloading the new map using TT home onto a rider 1. Again it says no map found. 1st time I did this same result so I put a back up on it worked fine with that. Downloaded the map again same result. Whats happening?
Any help as at the moment its no maps found
Noj
dhn
PostPosted: Fri Aug 21, 2009 1:28 am    Post subject: Reply with quote
Do you have the most recent application for your model?
harley-noj
PostPosted: Fri Aug 21, 2009 3:54 pm    Post subject: Reply with quote
Hi Just a quick update. Having had a happy 30 mins with TT support, during which time the application was removed and reload. I've still got the same problem. Its as if its the wrong map version for my rider. But support says its OK!!!
Now its get some screen shots of the contents and send off to 2nd line support
At least I can put the old map back on and use the rider whilst this gets sorted
Noj
harley-noj
PostPosted: Sat Aug 22, 2009 12:38 am    Post subject: Reply with quote
All the info TT asked for has now been sent.
So I tried the following, went back to an old application and map.
It worked.
Updated application, it worked,
Using home downloaded new map, cannot see it. deleted map, then added it using home.
IT WORKS!!!!!!!
Map is now 835.2421 is this the latest map?
App 7.901
Noj
dhn
PostPosted: Sat Aug 22, 2009 1:00 am    Post subject: Reply with quote
You have the latest map.
harley-noj
PostPosted: Sat Aug 22, 2009 12:09 pm    Post subject: Reply with quote
Thanks for the info, It was the only thing I wasn't sure about
Noj
22.062 (12 Jun 24)
