Pocket GPS World :: View topic - tomtom one 3rd editin format problem
nikissfan
PostPosted: Thu Aug 20, 2009 5:17 pm    Post subject: tomtom one 3rd editin format problem Reply with quote
hi,
my device stuck @ eprom screen. did hard reset.
i cant format my tomtom using xp to reinstall navcore
is there anyone who can help?
PostPosted: Thu Aug 20, 2009 8:02 pm    Post subject: Reply with quote
Slow down....
Do you really need to format it? You don't need to if all you want to do is reinstall Navcore.
Do you you have a previous backup of the system and maps to put back on it after a format? (If not, you'll have to buy a new map)
What happens when you connect the One to the PC? Can you still access the storage as a new disk drive in Windows? If so, what folders and files do you see?
What's the "eprom screen"? I've had plenty of crashes but never seen anything I'd immediately describe as that.
PostPosted: Fri Aug 21, 2009 3:27 pm    Post subject: Reply with quote
Could it be the back info screen you get if you hold the ON button in, and no SD Card inserted?
It might suggest that the Unit cannot 'see' the SD Card, because the Card is not Booting, or has failed.
nikissfan
PostPosted: Tue Aug 25, 2009 9:33 pm    Post subject: Reply with quote
hi,
after formatting tomtom my computer sees drive ok ,but wont let me add any files stating path not recognised. so i cant even restore my backup data!
Help!!!!!
nikissfan
PostPosted: Tue Aug 25, 2009 9:35 pm    Post subject: Reply with quote
Sorry i forgot to add that its a 1gig 3rd edition tt one. so theres no sd slot.
dhn
PostPosted: Tue Aug 25, 2009 9:38 pm    Post subject: Reply with quote
Since it appears you do have a backup, use Explorer to copy the contents of the backup to the unit.
If that works, make another (and ALL future) backup using Explorer. Ensure hidden files/folders are showing.
PostPosted: Tue Aug 25, 2009 9:51 pm    Post subject: Reply with quote
But nikissfan says:
How did you do the format, nikkisfan? It should be formatted to "FAT32" and don't use any quick format options.
Some instructions from TT are HERE.
If you can open an Explorer window on the drive, can you right click on the window and make a new text document? (I'm just wondering if the "path not recognised" error you are getting is for the path you are fetching the files FROM, rather then the path you are sending them TO).
PostPosted: Wed Aug 26, 2009 8:40 am    Post subject: Reply with quote
Did you not read Andy-P's post just less than 3 hours after your openning post which was apparantly made at 5 in the morning:shock:
Try getting a response that quick fromTT Very Happy
22.063 (19 Jun 24)
