sweepdog Occasional Visitor
Posted: Sat Aug 15, 2009 2:06 am Post subject: Road speed limit info |
When I first bought my TomTom Go 510, it came with UK maps and the speed limit shown was pretty accurately e.g. when going from 30 to 40 etc. Is this information limited to just motorways in the western European maps (due to the size of the database?) ?
I much preferred it when it was showing all the speed limits. (I got slated by the OH when TomTom took us down some windy roads in Cornwall which were probably longer once we knew how to avoid these, so I assume speed limit info would produce better routes) |
AliOnHols Pocket GPS Verifier
Posted: Sat Aug 15, 2009 7:38 am Post subject: |
Hi sweepdog. It's not just the motorways which have their road speeds showing on the european maps. Most of the roads near me in Spain have speeds associated with them (not necessarily the correct speeds though!). To display the max road speeds alter the settings in "Staus Bar Preferences" which is on page 4 of preference menu. Editing max road speeds is done via the "Map Corrections" icon in on the TT. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Aug 15, 2009 7:40 am Post subject: |
The Max Speed has to be set up in the Status Bar Menu. On the 1st page Select Speed, and on the 2nd page Select Show max speed next to speed.
Strange as it may seem, the speed indication has no bearing on the Route Calculation. There is a separate item, attached to the Map data, that holds the travel time for each section of road. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
young-goat Lifetime Member
Posted: Sat Aug 15, 2009 8:53 pm Post subject: |
Quote: | Strange as it may seem, the speed indication has no bearing on the Route Calculation. There is a separate item, attached to the Map data, that holds the travel time for each section of road. |
Is there any way to change these timings ? |
Posted: Sat Aug 15, 2009 9:50 pm Post subject: |
young-goat wrote: | Quote: | Strange as it may seem, the speed indication has no bearing on the Route Calculation. There is a separate item, attached to the Map data, that holds the travel time for each section of road. |
Is there any way to change these timings ? | No, it's hard coded. _________________ Richard
Posted: Sun Aug 16, 2009 12:51 am Post subject: |
There seemed to be already a tick my "show max speed next to speed", so I unticked "speed" from the previous menu and ticked it again. I'll see how I get on when I go out in the car next |
Posted: Sun Aug 16, 2009 10:00 am Post subject: |
sweepdog wrote: | There seemed to be already a tick my "show max speed next to speed", so I unticked "speed" from the previous menu and ticked it again. I'll see how I get on when I go out in the car next |
sweepdog, remember that not all roads have speeds associated to them, some will and others won't. So as you are driving along, you may or may not get advice regarding the speed of the road you are on, It all depends if TT have included the information in the map. It's Hit-n-Miss.
You can edit this by using the "Map Corrections" facility as described above if you wish to add &/or alter a speed to a road. _________________ Garmin Nuvi 2599
uk89camaro Regular Visitor
Posted: Sun Aug 16, 2009 12:02 pm Post subject: |
AliOnHols wrote: | sweepdog wrote: | There seemed to be already a tick my "show max speed next to speed", so I unticked "speed" from the previous menu and ticked it again. I'll see how I get on when I go out in the car next |
You can edit this by using the "Map Corrections" facility as described above if you wish to add &/or alter a speed to a road. |
excellent info, ta very much. _________________ Tom Tom 1005 v2 World, Garmin Dakota 20, IPhone 4S |
Posted: Sun Aug 16, 2009 7:31 pm Post subject: |
Not been out today, but I remember the speed area on motorways is shown as 70/70, but when I'm off the motorway, I just get my current speed. Does this mean something is missing (I assume to save space it has a global variable for motorway speed) |
DennisN Tired Old Man
Posted: Sun Aug 16, 2009 9:17 pm Post subject: |
The speed area is shown as xx/xx on any road where the map has the speed limit. If the road speed is recorded in the TT map as 30, it'll show 28/30 when you're doing 28. There is no global assumption of any speed limit. It's either recorded on the map and shows, or not recorded and you don't get anything.
The availability of the road speed limit is very, very far from 100%. So far as I'm, aware, it's simply that TT haven't (yet?) got speed limit data for the roads which don't show it - I have not seen any indication that they are dropping those details as maps "progress". There are also some wrong details. So whilst this feature is handy, please do REMEMBER, it's you who are responsible for observing the speed limit, not the TomTom device. _________________ Dennis
Two of them are obesiting!! |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Sun Aug 16, 2009 9:20 pm Post subject: |
AliOnHols wrote: | You can edit this by using the "Map Corrections" facility as described above if you wish to add &/or alter a speed to a road. |
Unfortunately the GO 510 doesn't have this functionality yet. _________________ Paul |
Posted: Sun Aug 16, 2009 10:56 pm Post subject: |
Dennis - re speeds. yes of course it's the road, but it used to amaze me how accurate the info was when we went into a new zone and just wondered what's happened to it (even on the same route) |
Posted: Mon Aug 17, 2009 12:11 am Post subject: |
Hmm, you must be far more observant than I. I've not noticed any roads which used to have speed limits which don't now have them. I don't suppose you can tell us an example (I have some maps which are two and a half years old and could look to see if that's the case on them)? _________________ Dennis
Posted: Mon Aug 17, 2009 6:40 am Post subject: |
pcaouolte wrote: | AliOnHols wrote: | You can edit this by using the "Map Corrections" facility as described above if you wish to add &/or alter a speed to a road. |
Unfortunately the GO 510 doesn't have this functionality yet. | If you have the latest App and Map it is there.
Under Report other error, Existing Street, Select street, Wrong speed limit. _________________ Richard
Posted: Fri Aug 21, 2009 11:35 pm Post subject: |
DennisN wrote: | Hmm, you must be far more observant than I. I've not noticed any roads which used to have speed limits which don't now have them. I don't suppose you can tell us an example (I have some maps which are two and a half years old and could look to see if that's the case on them)? | It's missing from all roads. I'm going to buy a new map - mine is quite out of date
Can someone remind me please. Is the App software held on the SD card? |
