Pocket GPS World :: View topic - Speed on green safety cameras
misterb206
PostPosted: Fri Aug 07, 2009 12:57 pm    Post subject: Speed on green safety cameras Reply with quote
Has any one else seen this
basically red light cameras are no being used as speed cameras when the light is green
here is a link for my local area explaining all @ DSC
and for the locals a list of there locations !! RED & GREEN
GerryC
PostPosted: Fri Aug 07, 2009 1:14 pm    Post subject: Reply with quote
These are quite common throughout the country. On the database from here they are labelled "Redspeed" and are in the gatso category based on the speed limit for passing through on green.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
aj2052
PostPosted: Sat Aug 08, 2009 12:51 am    Post subject: Reply with quote
It seems a bit of an irrevelent posting if you pass at red you get fined if you pass on green above the speed limit you get fined, the rules apply in all cases, coomon sense applies.
Moto G5s Plus, Sygic 17.4.8
PostPosted: Sat Aug 08, 2009 7:58 am    Post subject: Reply with quote
The list quoted is not of all the "Red/Green" cameras - look closely and you'll see there are only two listed, the others are normal redlight cameras. On Holes Bay Road, which is reasonable to expect as it can be a bit of a tempting racetrack.
We do, of course, have these two on our database, RedSpeed 8985 and 28625.
PostPosted: Sat Aug 08, 2009 11:46 am    Post subject: Reply with quote
Deleted - double post due to finger-trouble! Rolling Eyes
PostPosted: Sat Aug 08, 2009 11:48 am    Post subject: Reply with quote
As far as I know, they can't use the original "like Gatso but taller and thinner" redlight cameras for speeding too, they need to be replaced by one of the newer digital types.
Not these:
...but these:
goodstone
PostPosted: Sun Aug 09, 2009 10:27 pm    Post subject: Reply with quote
Perhaps a suggestion GPSWORLD should do a seperate warning for REDSPEED cameras on the database so at least i can then do a seperate alert for them. I know the laws just changed about monitrons doing both speed/redlight. My job is driving and i see these monitron cameras at red lights but they are indicated on database as speed cameras when infact there are no measurement markings at lights.
Ant
PostPosted: Sun Aug 09, 2009 11:41 pm    Post subject: Reply with quote
Quote from Dorset Safety Camera Partnership website...
drivers will notice that there are now secondary check lines on the road at applicable junctions.
So if they don't have the white road markings running through the junction as with all Gatsos, they're not speed cameras, just Redlights.
PostPosted: Mon Aug 10, 2009 8:26 am    Post subject: Reply with quote
Ant
in which case, please submit a change request to redlight.
PostPosted: Mon Aug 10, 2009 10:14 am    Post subject: Reply with quote
Ant
That would require another SEVEN categories (20-70 mph and TBC), and wouldn't give any extra benefits as far as I can see.
The way it should be working is that if it is a redspeed camera, you get notified as if it was a Gatso - with the correct speed limit indicated.
And if it is a simple redlight camera, you get the normal redlight cam. warnings.
If you really want to split them all out into separate categories, you can always use POIEdit to do it yourself.
PostPosted: Mon Aug 10, 2009 11:08 am    Post subject: Reply with quote
Andy_P wrote:
Ant
7 for uk (20 30 40 50 60 70 TBC)
14 for eu (20 30 40 50 60 70 80 90 100 110 120 130 TBC)
14 for usa (20 25 30 35 40 45 50 55 60 65 70 75 80 TBC)
so potentially 35 extra files
PostPosted: Mon Aug 10, 2009 11:28 am    Post subject: Reply with quote
MaFt wrote:
7 for uk
14 for eu
14 for usa
Yeah, but I can't afford to go on holiday this year! Laughing
