Pocket GPS World :: View topic - POI Name Change
POI Name Change
PostPosted: Sat Aug 01, 2009 5:15 pm    Post subject: POI Name Change Reply with quote
Hi, Can anyone tell if it is possible to change the name of a POI without having to delete it and start again. I decided to save all my favorites under one POI heading,but in doing so chose a naff name, now i would like to swap it for one more relivent/easier to find.
dhn
PostPosted: Sat Aug 01, 2009 5:35 pm    Post subject: Reply with quote
If you created a custom ov2. file then just use Explorer to rename the file. (If you've an associated .bmp file, remember to rename it to precisely what you're renaming the .ov2 file to.
1304
PostPosted: Sat Aug 01, 2009 6:59 pm    Post subject: Reply with quote
Err..No...Sorry mate, not a single word, do you know of a simple way, or should I just leave it as it is.
Calomax
PostPosted: Sat Aug 01, 2009 8:58 pm    Post subject: Reply with quote
Do you mean a POI category or an individual POI?
TT Go Essential
1304
PostPosted: Sun Aug 02, 2009 5:40 pm    Post subject: Reply with quote
A POI category
Daggers
PostPosted: Sun Aug 02, 2009 8:20 pm    Post subject: Reply with quote
If you named your POI category "Favourites", then your TT will have created two files in its map folder - one called Favourites.ov2 which contains the locations of each of your individual POIs, and one called Favourites.bmp which contains the picture displayed on your map at each of the relevant locations.
If you are used to using Windows Explorer, it's easy enough to connect the TT to your computer and rename these files. If you want to call the category, say MyPOIs, you must rename the two files to MyPOIs.ov2 & MyPOIs.bmp.
Garmin DriveSmart 50 LMT-D
Calomax
PostPosted: Mon Aug 03, 2009 8:46 am    Post subject: Reply with quote
Just to clarify daggers' reply, connect your device to your PC, ignore HOME if it starts up, go into "My Computer" and select your device then select your map folder, it will be called "Great Britain" or "Western Europe" or something similar.
Then find the POI category you want to change, and right-click on the .ov2 file and the .bmp file. You can then select "rename" and change them to whatever you like, so long as both names are the same.
Do not change the extension though (.ov2 & .bmp) or they just won't work.
TT Go Essential
1304
PostPosted: Mon Aug 03, 2009 11:07 am    Post subject: Reply with quote
Thanks Calomax sorted, it seemed a lot more compicated than that when dhn posted his reply, also to Daggers very much appreciated.
Calomax
PostPosted: Mon Aug 03, 2009 12:03 pm    Post subject: Reply with quote
Great, glad you got it sorted.
TT Go Essential
