Pocket GPS World :: View topic - Yet another Tyre question!!!!
chelsky
PostPosted: Mon Jul 27, 2009 3:25 pm    Post subject: Yet another Tyre question!!!! Reply with quote
Hi. I am going to Spain again in August and have just planned my route, using Tyre. Fine, no problem. The thing is I have missed out one of my stops on route. Embarassed I have loaded it on to TT before realizing my mistake. Is there anyway I can edit the route to include the other stopover? Also why does Jan reccomend using the shortest route because this really does mess up my route? It might be ok for motorbikes, which is what it was intended for but with an 8mtr. caravan on the back, No Good!!! Thank you.
Regards David
Rick-uk
PostPosted: Mon Jul 27, 2009 7:44 pm    Post subject: Reply with quote
You can load the current itinerary into tyre using the menu option
Tomtom, Active Route, Open active route from tomtom
then open it in google maps using show route. The option to add a new waypoint is at the bottom towards the left.
Either save your new route as an itinerary or use the menu option
Tomtom, Active Route, Copy to tomtom as active route
If you have previously saved it as an itn file then you can just open it in tyre and then save any changes
Does this help?
chelsky
PostPosted: Mon Jul 27, 2009 10:06 pm    Post subject: Reply with quote
Hi Rick-uk. That certainly does help. I will try it tomorrow and let you know how I get on. Thanks very much
chelsky Very Happy
chelsky
PostPosted: Tue Jul 28, 2009 8:16 pm    Post subject: Reply with quote
Hi Rick-uk.I have been experimenting with Tyre all afternoon. when I tried the active route option all I got was " This is not a valid TT file" I did manage to get the route back to tyre and add the missing stop over. I used a gps coordinate. It showed up when I browsed the text but completely missed it when it planned the route. In the end I started all over again. I obviously did something wrong because the original route contained two gps coordinates and they showed up. I will keep experimenting Laughing
chelsky
dhn
PostPosted: Tue Jul 28, 2009 9:36 pm    Post subject: Reply with quote
You may be interested in this link . It's a site put up by a NA member of a forum I moderate in North America.
All about using google/tyre/ and TomTom.
May help......
chelsky
PostPosted: Tue Jul 28, 2009 9:53 pm    Post subject: Reply with quote
Thanks for the link David. That information is available from the tyre website, so I am able to do the basics, it is just when I encounter a problem that I am lost Laughing
regards chelsky
sgould
PostPosted: Tue Jul 28, 2009 11:56 pm    Post subject: Reply with quote
How many waypoints on your route?
Tomtom used to have a limit on the number - 20?
Not sure if that still applies, but if it does and you have too many, you may confuse the system when transferring across.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
chelsky
PostPosted: Wed Jul 29, 2009 9:29 am    Post subject: Reply with quote
I didn't know that TT had limits on waypoints. I believe tyre has a 38 waypoint limit, so I assumed, as it is designed for TT that they would be the same. I could be wrong Laughing
chelsky
dhn
PostPosted: Wed Jul 29, 2009 11:24 am    Post subject: Reply with quote
The Go models can handle 48 waypoints/itinerary.
chelsky
PostPosted: Wed Jul 29, 2009 11:30 am    Post subject: Reply with quote
Thanks David
chelsky
Rick-uk
PostPosted: Wed Jul 29, 2009 4:51 pm    Post subject: Reply with quote
and tyre will prompt you to split the file into acceptable sizes (or remove waypoints) if you exceed the limit
