Pocket GPS World :: View topic - no search option streetpilot i3
dontcare1970
PostPosted: Wed Jul 22, 2009 4:44 pm    Post subject: no search option streetpilot i3 Reply with quote
Hi, HELP, I have just updated my maps on my streetpilot i3 with imgps2, and it has loaded fine but there is no search option to look for new addresses, any help will be wonderful.
Thanks Nick.
Pocketgps
PostPosted: Wed Jul 22, 2009 5:52 pm    Post subject: Reply with quote
What is imgps2. I have several i3's and have never seen that update.
dontcare1970
PostPosted: Wed Jul 22, 2009 7:51 pm    Post subject: Reply with quote
IMG2GPS is a Windows GUI for the SendMap / Sendmap20 DOS application by gps_mapper.
It will transfer any Map file (.img format) to your Garmin GPS.
It will work for Garmin maps as well as home-made maps.
PaulB2005
PostPosted: Thu Jul 23, 2009 6:06 am    Post subject: Reply with quote
What map did you load?
Pocketgps
PostPosted: Thu Jul 23, 2009 3:13 pm    Post subject: Re: no search option streetpilot i3 Reply with quote
Thanks Nick.
Can you select the Garmin map in the i3's menus, or have you only loaded a none Garmin map.
I would think that a none Garmin map would not contain the address data needed to use the search function. Not sure what would happen if you selected the Garmin map in the i3's menu, then searched address to navigate to, then switched maps in the i3's menu Laughing
What happens if you use this program to just load the original Garmin map, does the search work then. If not it would seem that the program cannot handle the address data or strips it away when loading it.
PostPosted: Thu Jul 23, 2009 3:27 pm    Post subject: Reply with quote
pretty certain that SOME of the garmin maps don't do routing - eg the Metro Guide i'm sure did not have routing, just actual maps. maybe it was one of those maps?
Pocketgps
PostPosted: Thu Jul 23, 2009 3:35 pm    Post subject: Reply with quote
You could be right MaFt Laughing
When you use Garmin's MapSource to load a road map, it can take ages to compile the index/address data before it transfers it to the device.
22.105 (30 Oct 24)
