ixion Occasional Visitor
Posted: Mon Jul 20, 2009 6:39 pm Post subject: Tomtom 910 switching off problem |
Hi All,
My mate has a Tomtom 910 which now when turned on the blue (loading bar scrollsa across the screen then it gets to the Tomtom splash screen then just turns off every time, any ideas please? _________________
dhn Frequent Visitor
Posted: Mon Jul 20, 2009 6:43 pm Post subject: |
Suggest he try a reset of the unit. _________________ David |
Posted: Mon Jul 20, 2009 6:49 pm Post subject: |
dhn wrote: | Suggest he try a reset of the unit. |
That is the first thing we tried, makes no difference! _________________
Posted: Mon Jul 20, 2009 6:57 pm Post subject: |
Okay, how about uninstalling and reinstalling the application?
Does the computer recognize the existence of the unit as an external drive? If so, use Explorer to make a complete backup of the unit's contents, ensuring hidden files/folders are showing.
Now, use Explorer to delete all the loose files in the root of the unit, NO folders or their contents.
Start Home. Should recognize the unit is missing an application and offer to dl and install it. Let it do so.
Disconnect the unit PROPERLY from the computer using the Safely Remove Hardware icon in the notification area or Home's Device/Disconnect.
Start up the unit. Any better? _________________ David |
Posted: Mon Jul 20, 2009 7:13 pm Post subject: |
Does it do this when connected to the charger either on the computer (remember there is a seperate charger lead for the home dock) or when its connected to the car charger?
If its OK when running from an external power supply then the internal battery is probably shot - Mike |
Posted: Wed Jul 22, 2009 4:27 pm Post subject: |
mikealder wrote: | Does it do this when connected to the charger either on the computer (remember there is a seperate charger lead for the home dock) or when its connected to the car charger?
Mike, it did the same when connected up to the mains charger. _________________
Posted: Wed Jul 22, 2009 4:30 pm Post subject: |
dhn wrote: |
Start up the unit. Any better? |
David, thanks for the advice, did all what you said and it worked and booted up.
HOWEVER, now when I switch on the screen just flickers for a split second and wont turn on unless I stick a paperclip in the reset hole then it will startup fine. But it wont start up without a reset, any ideas? _________________
Posted: Wed Jul 22, 2009 5:46 pm Post subject: |
I do believe I've read where some have had to do the rest thing about 3 times in a row before the resetting 'stuck'. Try it. _________________ David |
Posted: Wed Jul 22, 2009 5:59 pm Post subject: |
dhn wrote: | I do believe I've read where some have had to do the rest thing about 3 times in a row before the resetting 'stuck'. Try it. |
Hi David,
Not quite sure what you mean? _________________
Posted: Wed Jul 22, 2009 6:33 pm Post subject: |
Do a pin set.
Then, after it starts up, do another pin reset.
Turn it on and do a third pin reset. _________________ David |
MarnieCrittle Occasional Visitor
Posted: Sun Aug 30, 2009 10:01 pm Post subject: 910 switching off |
Bit late in the day but from my experience the 910 will not run on a charger if the battery is shot. Had two battery replacements so far, could not get the unit to stay on. Now I try to keep the battery fully charged as much as possible, I used to only have it on the charger in the car.
Marnie |
