Pocket GPS World :: View topic - cannot open com1 port does not exist error
wintir
PostPosted: Tue Jun 29, 2004 10:42 pm    Post subject: cannot open com1 port does not exist error Reply with quote
Hi all,
I have a Qtek2020 (XDAII) and purchased a haicom 204s system.
I also installed tom tom 3. Now, when I want to setup the gps, i can choose between:
Infrared Port
Com4:
Com5:
Bt on com6
Serial Cable on Com1
Com9
Com2
Serial on USB
Bluetooth GSP
I figure I have to use "serial cable on COM1", but when I check the box, I always recieve: cannot open com1: port does not exist.
What can I do? I tried other ports, but no succes...
TIA
Winny
nej
PostPosted: Wed Jun 30, 2004 9:09 am    Post subject: Reply with quote
I don't know if this will help, but on the XDA-I the Infra-red port tied up the COM port.
Try going to, Settings, Connections, Beam and unticking Receive Incoming Beams.
HTH,
-Neil
PostPosted: Wed Jun 30, 2004 2:28 pm    Post subject: Reply with quote
Also clip-on keyboards or external keyboards often use a driver that locks COM1, some of these drivers can be de-activated in software, other require removal to restore access to COM1.
chunkybloke1
PostPosted: Fri Jul 02, 2004 6:21 pm    Post subject: Fixed it for me Reply with quote
Brilliant bit of advice Neil. Thumbs Up
dflo
PostPosted: Wed Jul 14, 2004 10:42 pm    Post subject: cannot open com1: Reply with quote
:D Thanks for this advice; in my case I got the message: cannot open com1: port does not exist.
It was because of the driver of the foldable keyboard I use; after removal (settings) the GPS was found and it's functioning very well (Ipaq 3970 with Haicom gps 204s)
ddocg
PostPosted: Fri Oct 01, 2004 11:30 pm    Post subject: Reply with quote
the removal of the keyboard worked for my 2210 though any suggestions on how i can use the keyboard ?
PostPosted: Fri Oct 01, 2004 11:36 pm    Post subject: Reply with quote
All you have to do is disable the driver (untick the connected/ActiveSync/Enabled box) in the driver applet and you can use your bottom COM port.
ddocg
PostPosted: Mon Oct 04, 2004 8:19 pm    Post subject: Reply with quote
Please excuse my ignorance, can i ask where this applet can be found ?
PostPosted: Mon Oct 04, 2004 8:30 pm    Post subject: Reply with quote
It depends on the make and model of keyboard, following installation most have a configuration applet under 'Settings' or possibly even 'Programs'.
Not all however include the facility to turn On/Off their COM Port driver, if yours does then you can leave it installed and just turn it ON when you need it otherwise you need to remove it when ever you need access to COM1 which is far from convenient Sad
ddocg
It's Ok i managed to figure it out under Programs/iPaq Foldable Keyboard
ddocg
PostPosted: Mon Oct 04, 2004 8:33 pm    Post subject: Reply with quote
I'm just about to go and see if the navigator is working, i'm quite sure it is as i did not receive a com port warning when i tried starting the navigator up.
22.064 (26 Jun 24)
