Pocket GPS World :: View topic - European Voice warnings (KPH) and Ash10?
skellum
PostPosted: Fri Jul 17, 2009 2:15 pm    Post subject: European Voice warnings (KPH) and Ash10? Reply with quote
I wondered if you have any Ash 10 compatible voice files for European (KPH) warnings..and if not, can I convert any of those available@
All advice gratefully received..
PaulB2005
PostPosted: Fri Jul 17, 2009 2:37 pm    Post subject: Reply with quote
I assume you mean Ash10 Camera Manager?
Ash10 doesn't do European (KPH) database files, so there are no Ash10 European (KPH) warnings.
PaulB2005
PostPosted: Fri Jul 17, 2009 2:40 pm    Post subject: Reply with quote
If you have European Voice Files just rename the files to match the CSV / GPX files you use. All POILoader does is match the mp3 and the CSV / GPX file with exactly the same names and assigns the sound from the mp3 to the warning location from the CSV / GPX file.
skellum
PostPosted: Fri Jul 17, 2009 4:17 pm    Post subject: Reply with quote
Yes, I should have said Ash 10 Camera Manager.. having looked at the voices I see there is a KPH one (Andy Siddell) but if I understand the text correctly, I guess that means it converts the KPH to MPH and then gives you an adjusted MPH warning rather than straightforward KPH.
EU (MPH) Voice Set - Speed zoned only and formatted for KPH alerts.
Thanks for your advice..
PaulB2005
PostPosted: Fri Jul 17, 2009 5:42 pm    Post subject: Reply with quote
...if I understand the text correctly, I guess that means it converts the KPH to MPH and then gives you an adjusted MPH warning rather than straightforward KPH.
Ah "EU (MPH) Voice Set" is a typo. Should say "EU (KPH) Voice Set"
The only voices that work with Ash10 CM are Liz Whitaker ASH10 Camera Manager Version UK (MPH) Voice Set and Graham ASH10 Camera Manager Version UK (MPH) Voice Set.
The other MPH Voices work with the normal PGPSW MPH database and the other KPH voices work with the normal PGPSW KPH databases. None of the KPH voice work with the Camera Manager database as it produces no KPH files.
skellum
PostPosted: Fri Jul 17, 2009 6:03 pm    Post subject: Reply with quote
The other MPH Voices work with the normal PGPSW MPH database and the other KPH voices work with the normal PGPSW KPH databases. None of the KPH voice work with the Camera Manager database as it produces no KPH files.[/quote]
Thanks for the info...I guess it will be back to the Bongs again!!
cheers..Tony
PaulB2005
PostPosted: Fri Jul 17, 2009 6:22 pm    Post subject: Reply with quote
I'm not sure i follow....
If you are using the KPH database why not use the KPH voices? The confusion has arisen because you asked about the Ash10 Camera Manager KPH Database, but there isn't one.....
If you are using Ash10s Camera Manager for the MPH database then use one of the 2 voices mentioned above.
If you want to use a KPH database then use a PGPSW one and use one of the KPH voices. There's no reason to go back to the bongs for either..
22.064 (26 Jun 24)
