skellum Lifetime Member
Posted: Fri Jul 17, 2009 2:15 pm Post subject: European Voice warnings (KPH) and Ash10? |
I wondered if you have any Ash 10 compatible voice files for European (KPH) warnings..and if not, can I convert any of those available@
All advice gratefully received.. |
Posted: Fri Jul 17, 2009 2:37 pm Post subject: |
I assume you mean Ash10 Camera Manager?
Ash10 doesn't do European (KPH) database files, so there are no Ash10 European (KPH) warnings. |
Posted: Fri Jul 17, 2009 2:40 pm Post subject: |
If you have European Voice Files just rename the files to match the CSV / GPX files you use. All POILoader does is match the mp3 and the CSV / GPX file with exactly the same names and assigns the sound from the mp3 to the warning location from the CSV / GPX file. |
Posted: Fri Jul 17, 2009 4:17 pm Post subject: |
PaulB2005 wrote: | If you have European Voice Files just rename the files to match the CSV / GPX files you use. All POILoader does is match the mp3 and the CSV / GPX file with exactly the same names and assigns the sound from the mp3 to the warning location from the CSV / GPX file. |
Yes, I should have said Ash 10 Camera Manager.. having looked at the voices I see there is a KPH one (Andy Siddell) but if I understand the text correctly, I guess that means it converts the KPH to MPH and then gives you an adjusted MPH warning rather than straightforward KPH.
EU (MPH) Voice Set - Speed zoned only and formatted for KPH alerts.
Thanks for your advice.. |
Posted: Fri Jul 17, 2009 5:42 pm Post subject: |
Quote: | ...if I understand the text correctly, I guess that means it converts the KPH to MPH and then gives you an adjusted MPH warning rather than straightforward KPH. |
Ah "EU (MPH) Voice Set" is a typo. Should say "EU (KPH) Voice Set"
The only voices that work with Ash10 CM are Liz Whitaker ASH10 Camera Manager Version UK (MPH) Voice Set and Graham ASH10 Camera Manager Version UK (MPH) Voice Set.
The other MPH Voices work with the normal PGPSW MPH database and the other KPH voices work with the normal PGPSW KPH databases. None of the KPH voice work with the Camera Manager database as it produces no KPH files. |
Posted: Fri Jul 17, 2009 6:03 pm Post subject: |
The other MPH Voices work with the normal PGPSW MPH database and the other KPH voices work with the normal PGPSW KPH databases. None of the KPH voice work with the Camera Manager database as it produces no KPH files.[/quote]
Thanks for the info...I guess it will be back to the Bongs again!!
cheers..Tony |
Posted: Fri Jul 17, 2009 6:22 pm Post subject: |
I'm not sure i follow....
If you are using the KPH database why not use the KPH voices? The confusion has arisen because you asked about the Ash10 Camera Manager KPH Database, but there isn't one.....
If you are using Ash10s Camera Manager for the MPH database then use one of the 2 voices mentioned above.
If you want to use a KPH database then use a PGPSW one and use one of the KPH voices. There's no reason to go back to the bongs for either.. |
